AFN Intake Manifold: Large & High Performance
Go to page: 1, 2  Next
dj1
Post09-10-2006, 21:12    Subject: AFN Intake Manifold: Large & High Performance Quote
Hello everyone,
I wanted to show you my new intake manifold for my AFN (Golf 3).
'This thing is really cool, and it lets a lot more air through than the original one; you can already see that in the pictures!'
The intake manifold comes from a Volkswagen Passat with a 130 horsepower engine.
You just need to attach an adapter, and then you can use it without any problems.
DJ.
Sure, here's the translation:
'P.S.: Of course, I expanded it to cover gasket sizes icon_lol.gif'
 File size:  1.01 MB
 Viewed:  3348 times
 File size:  351.61 KB
 Viewed:  2882 times
 File size:  1.15 MB
 Viewed:  3712 times
Translated on 12-08-2026, 16:09.
Post09-10-2006, 21:16    Subject: AFN Intake Manifold: Large & High Performance Quote
Nice project! Do you also have any log files that show the air mass at full load before and after the modification?
Translated on 12-08-2026, 16:11.
dj1
Post09-10-2006, 21:18    Subject: AFN Intake Manifold: Large & High Performance Quote
Best regards, Rainer,
Well, my cylinder head is currently being worked on using a flow bench.
'That will give me the airflow readings before and after, each with this intake manifold.'
DJ.
FaBu
Karma: +3 / -1   Thank you, like it!
Post09-10-2006, 21:21    Subject: AFN Intake Manifold: Large & High Performance Quote
Since the heads of the AFN, 1Z, and AHU engines are the same, shouldn't this also be possible with the smaller TDI engines?
Bj.97 Golf Vari. AHU/CTN def.AGR;-)
100km/5L
0,216 Düsen, Kaufmann Chip,VR6 LuFiKa
Translated on 12-08-2026, 16:12.
Post09-10-2006, 21:24    Subject: AFN Intake Manifold: Large & High Performance Quote
FaBu wrote:
Since the heads of the AFN, 1Z, and AHU engines are the same, it should also be possible with the "smaller" TDI engines, right?
Sincerely
Yes, I'm definitely curious to see the results...
Translated on 12-08-2026, 16:13.
dj1
Post09-10-2006, 21:25    Subject: AFN Intake Manifold: Large & High Performance Quote
Since the heads of the AFN, 1Z, and AHU engines are the same, it should also be possible with the 'smaller' TDI engines, right?
Sincerely
I think so.
DJ.
Translated on 12-08-2026, 16:14.
Post09-10-2006, 21:35    Subject: AFN Intake Manifold: Large & High Performance Quote
aaaaaaaaaaahhhhhhhhhhhhh
Finally, someone who can put my ideas into action.
I never had a reliable source to get replacement nipples at reasonable prices.
"However, I knew that the one from the Passat would fit because the seal is the same."
tip: Also use the parking brake; your engine mounts will thank you for it!
Where did you get those socks?
VW wants more than 200 euros for it.
Here is the first documented mention.
February 9, 2005.
Okay, I'm ready. Please provide the German text you want me to translate into English.
 File size:  109.81 KB
 Viewed:  5163 times
Translated on 12-08-2026, 16:15.
dj1
Post09-10-2006, 21:40    Subject: AFN Intake Manifold: Large & High Performance Quote
tip: also use the drain plug, your engine mounts will thank you for it!!!
Was meinst du mit Abstellklappe? Huh?
The stem is made of steel and then shaped using a flexible grinder and some filing – it's not rocket science.
DJ.
Translated on 12-08-2026, 16:17.
dj1
Post09-10-2006, 21:44    Subject: AFN Intake Manifold: Large & High Performance Quote
My windshield motor also has such an intake manifold like your 1Z icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif.
There must be *fun* icon_wink.gif.
DJ.
Translated on 12-08-2026, 16:18.
Post09-10-2006, 21:49    Subject: AFN Intake Manifold: Large & High Performance Quote
Here's a comparison of what the "Stutzen" (a type of gaiter or protective covering) does for the 1Z (likely referring to a specific product or system):
 File size:  145.14 KB
 Viewed:  5178 times
Translated on 12-08-2026, 16:19.
Post09-10-2006, 22:00    Subject: AFN Intake Manifold: Large & High Performance Quote
Hmm?
What do I mean by "shut-off valve"?
Hold the access panel closed.
The part where the EGR valve is located also has a flap inside that can completely seal off the passage. It's pneumatically controlled up to Euro 3 standards, and from Euro 4 onwards, it uses an electric motor (acting as a proper throttle valve).
When stopped, it closes, which causes the pistons to leak out of the vacuum and prevents a "dumping" stroke. This eliminates the loud noise that engines like the 1Z, AHU, and AFN make when being turned off.
Okay, the anti-lag system might reduce some engine roughness, but my 1Z sounds terrible.
 File size:  116.35 KB
 Viewed:  4061 times
Translated on 12-08-2026, 16:20.
dj1
Post09-10-2006, 22:04    Subject: AFN Intake Manifold: Large & High Performance Quote
The AFN has no throttle valve or anything like that.
Just put a 60mm hose over the nozzle and it's good icon_cool.gif.
DJ.
Translated on 12-08-2026, 16:22.
Post09-10-2006, 22:09    Subject: AFN Intake Manifold: Large & High Performance Quote
YES!!!
That's exactly why you now have this unique and easy opportunity to upgrade that flap with the 130 horsepower Passat trim.
If I do this on the 1Z, I'll have to build an adapter first because the lid only fits the 3-bolt flanges, and I only have the hose connection.
But you just keep adding to it, and that's it.
Since the AFN already has the EDC15, you also have the downstream signals from the engine control unit (ECU). So, simply add a relay between the ESP disabler and relay 109, and the electrical connection is complete. Specifically, when the EDC still has power but the ELAB is shutting down, the bypass valve should also close.
... and soon your 200 horsepower rocket will be running smoothly.
For inquiries: 038 131 501 AA or ... G (you don't need the shortened version).
Translated on 12-08-2026, 16:24.
reuselkopp
Post10-10-2006, 15:35    Subject: AFN Intake Manifold: Large & High Performance Quote
Am I correct in assuming that the EGR valve is not installed at the same time, or does it then sit between the adapter and the throttle body?
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 12-08-2026, 16:25.
dj1
Post10-10-2006, 15:55    Subject: AFN Intake Manifold: Large & High Performance Quote
Am I correct in assuming that the EGR valve will not be installed, or does it then sit between the adapter and the throttle body?
Okay, as I said, I do everything without a throttle valve.
I'll leave out the AGR part - of course.
Simply slide the rubber hose over the adapter and you're done.
You can probably omit the AGR (Abgasrückführung valve) here because nothing essential seems to be missing.
As usual, a 5mm steel plate is placed over the EGR hole with a gasket.
DJ.
Translated on 12-08-2026, 16:26.
dj1
Post22-10-2006, 16:00    Subject: AFN Intake Manifold: Large & High Performance Quote
Hello everyone,
Okay, the head is completely finished (complete program icon_cool.gif).
'@Rainer K.: You can find the flow rate values before and after using the large intake manifold in the attachment.'
It should be noted that the previous flow rate was with the original head and a large intake manifold.
The flow rate after modification is achieved with a head featuring enlarged channels and a large suction pipe.
DJ.
 File size:  198.8 KB
 Viewed:  1492 times
 File size:  341.72 KB
 Viewed:  1490 times
 File size:  832.2 KB
 Viewed:  1509 times
 File size:  1010.23 KB
 Viewed:  1542 times
 File size:  267.93 KB
 Viewed:  1522 times
Translated on 12-08-2026, 16:28.
No new posts Large Navigation Multifunction Display Electrical Systems, Vehicle Electronics, Multimedia
No new posts Big thanks to Michael II... Diesel Engine Technology
No new posts Major problem, emergency mode Diesel Engine Technology
No new posts AGR Valve for 038 Engines Diesel Engine Technology
