18263 Data bus drive software status monitoring (data bus drive)
I would say that a control unit on the data bus, specifically related to the drivetrain, detected that another unit was not running the correct (original) software version.
Okay, this is about incorrect software versions or faulty control units that are installed in the CAN drive system. If you can ensure that the control units and software versions are correct, then the error can be ignored.
