A3: No Radio Power When Ignition Off?
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post22-02-2006, 10:32    Subject: A3: No Radio Power When Ignition Off? Quote
Hello!
I'm having a problem with my A3 that I haven't been able to solve myself yet. Normally, the power to the radio only goes off when you remove the ignition key from the ignition. At least, that's how it was with my previous A3 and Golf 2. So, it should also be possible with my current A3, model year 2002. The problem is, I can't find this darn cable icon_evil.gif. I've already measured the main wires of the fuse box, but I can only find constant positive voltage or ignition positive voltage.
Does anyone know where I can find the necessary power source, or does anyone have a wiring diagram for the A3 that I can use to extract the information myself?
The standard ISO connector of the radio strangely only provides constant positive power icon_question.gif. In order for me to get switched positive power, I already had to run a cable from the fuse box to the radio...
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Translated on 18-10-2026, 16:11.
Back to top Profile PM Email
Herr Antje
Post22-02-2006, 11:33    Subject: A3: No Radio Power When Ignition Off? Quote
The ISO connector always has "ignition power," or rather, that positive voltage that's activated when the ignition key is turned. Is the ISO connector properly connected, or are the cables disconnected and lying somewhere inside the dashboard?
If the connector is present but not working, it could be a broken wire or an issue with the ignition switch. I'm not sure if this positive connection also goes through the fuse box.
http://www.selfmadehifi.de/kfz-iso.htm
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 18-10-2026, 16:13.
mahk
Avatar-mahk
Post22-02-2006, 11:40    Subject: A3: No Radio Power When Ignition Off? Quote
I have a Blaupunkt Dallas MD70 in my A4 and initially had the exact same problem. The solution is to swap the constant power connection and the ignition connection (as far as I know, these are the first and third connections in the upper row).
But the most relevant link has already been posted above...
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Translated on 18-10-2026, 16:14.
Herr Antje
Post22-02-2006, 11:47    Subject: A3: No Radio Power When Ignition Off? Quote
@mahkViewing profile: mahk
I once experienced something similar. In that case, I realized it because the radio would work when connected, but the saved stations would disappear after turning off the ignition.
Aktuell:
wbuchi82
Post22-02-2006, 13:17    Subject: A3: No Radio Power When Ignition Off? Quote
Well, the problem is that my ISO connector only has the following cables connected to it.
1. Long-lasting plus.
2. Mass.
3. Amplifier for electric antenna.
That's why I tapped into a switched positive wire directly from the fuse box and connected it to the radio. It's not the problem that the settings aren't saved; that all works perfectly. The issue is that when I turn off the engine, the power to the radio immediately cuts off. Normally, the radio only turns off when I remove the key from the ignition.
The ISO connector seems to be complete, as the protective casing starts immediately behind the connector and shows no signs of damage. Furthermore, the previous owner had already rerouted the switched positive wire away from the fuse box. In my previous 1999 A3, all of this was already included in the ISO connector, and the radio is the same model as well.
Translated on 18-10-2026, 16:15.
Herr Antje
Post22-02-2006, 13:42    Subject: A3: No Radio Power When Ignition Off? Quote
Okay, that's new to me. It worked on my A3. However, it didn't have an electric antenna, or are you talking about an antenna amplifier (I can't even remember, I thought it wasn't in the ISO connector)? In any case, that's where I would start and carefully check that connection again. What was missing in my car was the radio mute function (it also didn't have a hands-free system from the factory).
If you can't find what you're looking for, you absolutely need a wiring diagram that shows the location of the radio, fuse box, and ignition switch. Unfortunately, I can't provide that.
Aktuell:
Translated on 18-10-2026, 16:17.
Post23-02-2006, 21:06    Subject: A3: No Radio Power When Ignition Off? Quote
Disclaimer: No warranty.
Given the year your car was manufactured, the switching signals (radio on, lights, etc.) are likely already transmitted via CAN-Bus. However, these signals should then be present in the ISO connector. This should be solvable with a CAN-Bus adapter from the aftermarket.
My G3 is much older, so everything is without guarantee, but it might be worth looking into this direction.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 18-10-2026, 16:18.
Post23-02-2006, 21:44    Subject: A3: No Radio Power When Ignition Off? Quote
Basically correct, but then the car would need to have a FAKRA connector, like the G5.
http://www.golf5-sound.de/Quadlock.jpg
This connection has been in use at Audi since MJ02.
What kind of radio was originally installed in the vehicle?
Translated on 18-10-2026, 16:19.
wbuchi82
Post25-02-2006, 17:41    Subject: A3: No Radio Power When Ignition Off? Quote
Hi!
Thank you for the answers!
So, when I bought the car last year, there was no radio installed because the previous owner had already replaced the original one. Unfortunately, I don't know which radio was installed before, or whether an original Audi radio was ever fitted.
Okay, then I'll take a closer look at that part again and trace the cable a bit further.
Translated on 18-10-2026, 16:21.
wolfi_b
Post26-02-2006, 12:44    Subject: A3: No Radio Power When Ignition Off? Quote
On the B4 model, there's a 0.5mm² red wire at the control unit (KI) that has voltage as long as the key is in the ignition. It's possible that the wire color is the same on yours...
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sleep Mode control units when the key is in the ignition? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Engine won't start when the radio is on Diesel Engine Technology
No new posts Car Radio Issues: Problems When Starting Engine Diesel Engine Technology
No new posts Car Radio No Sound at Startup? Troubleshooting Transmission, Chassis, Body & Interior
