Rim Damage: Causes and Repair Options
Post18-03-2008, 9:49    Subject: Rim Damage: Causes and Repair Options Quote
Can someone explain to me what kind of damage this is?
http://i21.ebayimg.com/04/i/000/d0/f0/d0b2_1.JPG
It doesn't look like bearing damage; it seems more like corrosion that has eaten away under the paint.
But then again, they are too thin and long!?!?
Can this be polished and repainted?
Thank you.
Translated on 20-08-2026, 12:01.
Post18-03-2008, 12:02    Subject: Rim Damage: Causes and Repair Options Quote
Just on the surface? Wheel cleaner residue??
Post18-03-2008, 13:14    Subject: Rim Damage: Causes and Repair Options Quote
I don't know, because the rims still icon_wink.gif belong to someone else.
Translated on 20-08-2026, 12:02.
Held467
Post18-03-2008, 14:01    Subject: Rim Damage: Causes and Repair Options Quote
Hello.
I would say those are salt intrusions.
Dirk
Karma: +1100 / -0   Thank you, like it!
Post18-03-2008, 21:37    Subject: Rim Damage: Causes and Repair Options Quote
Most likely salt damage. The cause was probably very small stone chips that damaged the clear coat layer. The rest happens on its own.
In my opinion, polished and sealed aluminum alloy wheels are not built to last forever. I would have them bead-blasted with ice or glass beads and then insist that the painter I trust least applies the coating. I would also have them repainted and perhaps ask the painter not to "cure" the clear coat quite as intensely, as this makes it more resistant.
Translated on 20-08-2026, 12:03.
No new posts What are they anchored to? Diesel Engine Technology
No new posts .clb Files: What are they and how to open? On-Board Diagnostics (OBD)
No new posts NGS and IRUE: Definitions and Explanations On-Board Diagnostics (OBD)
No new posts Trabold Side Channel Filters: Specs & Performance Diesel Engine Technology
