Fuel Injector AFN
dj1
Post19-03-2006, 12:48    Subject: Fuel Injector AFN Quote
Hello everyone,
Since I plan to upgrade to 12mm injectors soon, I've purchased a second fuel injector pump.
This was installed in a Sharan with a 110 HP engine (part number: 028130115 B).
Question:
Can I use this for my Volkswagen Golf (AFN model)?
The pumps in the Golf probably have part number 028130115 A.
Is there a difference between the pumps, or was I just lucky?
DJ.
Translated on 28-10-2026, 12:34.
TDI-NAXTEX
Post20-03-2006, 10:49    Subject: Fuel Injector AFN Quote
Yes, that is possible without any problems, but you will need to rewire the connector from the 10-pin connector to an 8-pin and a 3-pin connector.
Translated on 28-10-2026, 12:35.
dj1
Post20-03-2006, 16:50    Subject: Fuel Injector AFN Quote
Yes, that is possible without any problems, however, you will need to rewire the connector from a 10-pin connector to an 8-pin and a 3-pin connector.
How should I do that?
So, are the plugs the difference?
DJ1.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 Injection Pump Diesel Engine Technology
No new posts CAV Injection Pump Diesel Engine Technology
No new posts SDI Fuel Injector: Performance & Reliability On-Board Diagnostics (OBD)
No new posts Injection Pump 1Z - Buy Now! Diesel Engine Technology
