ARL Turbo Lag: Causes and Solutions
michel1234
Post05-04-2006, 15:55    Subject: ARL Turbo Lag: Causes and Solutions Quote
Hi.
I noticed the following with my G4 ARL:
When I accelerate in third gear, at approximately 2200 RPM, it feels like there's a slight turbo lag. Then, it takes about half a second for the turbo to build boost.
It's only noticeable within a specific RPM range. Below and above that, there's nothing. You can immediately feel the turbo kicking in with every press of the accelerator. As I said, I only notice it in third gear.
Is that normal? If not, what could it be?
Thank you for your responses.
Translated on 05-08-2026, 7:45.
Post06-04-2006, 20:16    Subject: ARL Turbo Lag: Causes and Solutions Quote
How do you conclude that it's related to the boost pressure?
Did you actually measure that in this situation, or is it just a colloquial description that the tractor isn't pulling?
Because simply increasing the turbocharger pressure won't generate power; diesel fuel needs to be injected as well.
If there is boost pressure present, but for some other reason not enough fuel is being injected, the error pattern will look completely different than if the turbocharger is actually "stuck."
Can you provide some reliable data, preferably VAG-COM logs?
Translated on 05-08-2026, 7:47.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Chip tuning" only possible with the original tuner On-Board Diagnostics (OBD)
No new posts Engine Misfire: Starting Issues & Troubleshooting Diesel Engine Technology
No new posts Log files related to the "thinking pause" issue when acce... Upload
No new posts Snorkeling / "Kaudern": known. TDI AWX error? Diesel Engine Technology
