TFSI ECU Diagnosis: Troubleshooting Guide
hans1807
Post22-02-2009, 9:49    Subject: TFSI ECU Diagnosis: Troubleshooting Guide Quote
Hello, can anyone tell me if the engine control units (ECUs) of the TFSI engine generation with MED9.1 can still be accessed via the K-line? The engine is being installed in a vehicle without CAN bus connectivity, which is why I'm asking. According to the wiring diagram, for example, in the A3, the K-line is routed from both the transmission control unit and the engine control unit. This specifically concerns an ECU from a BWA engine.
Translated on 10-08-2026, 16:08.
No new posts Chain rattle in Audi A5 TFSI CJE General Tips
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Diagnosis of control unit without a vehicle On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts KKL/KL Diagnosis: Causes & Treatment Diesel Engine Technology
No new posts Diagnosis On-Board Diagnostics (OBD)
