hollari Guest
31-07-2006, 8:59 Subject: Relay Explained: What Does It Do? (Image) |
Hello!
I just replaced this relay because the positive terminal was burnt.
and the engine was making such a strange noise at +30 degrees Celsius.
I always thought that was the preheating relay, but I'm not entirely sure.
be, because 1. It's only protected with a 30A fuse, and 2. it's a bit too small for that.
lots of cables attached.
1 x Thick power cable.
1 x Thick derivative.
1x Thin derivative.
1 x 3-pin connector with thin wires.
Is it possible that this relay controls the water heater?
| Description: |
| File size: |
97.1 KB |
| Viewed: |
8158 times |
Translated on 07-09-2026, 18:13.
bastion Blaumann
31-07-2006, 9:30 Subject: Relay Explained: What Does It Do? (Image) |
And in which car is that thing installed?
A4 Avant 08/01 AWX 05/08-
Translated on 07-09-2026, 18:14.
31-07-2006, 9:59 Subject: Relay Explained: What Does It Do? (Image) |
It looks like a Golf 3.
Is that the relay for the coolant heater?
Translated on 07-09-2026, 18:15.
Profile PM Garage |
hollari Guest
31-07-2006, 10:03 Subject: Relay Explained: What Does It Do? (Image) |
Oops. It's a Vento TDI.
hollari Guest
31-07-2006, 16:10 Subject: Relay Explained: What Does It Do? (Image) |
And where can I find the glow plug relay?
I've already searched everywhere in the engine compartment, but I haven't found anything.
31-07-2006, 18:17 Subject: Relay Explained: What Does It Do? (Image) |
It should be located above the central electrical panel (until around 1996), unless it's attached to the coolant reservoir (from around 1996 onwards).
Translated on 07-09-2026, 18:16.
Profile PM Garage |
hollari Guest
31-07-2006, 20:45 Subject: Relay Explained: What Does It Do? (Image) |
@dieselmartin:
'By 'Zentralelektrik', do you mean the fuse and relay holder?'
over the pedals, right?
01-08-2006, 14:30 Subject: Relay Explained: What Does It Do? (Image) |
Yes, that's what the person who coined the phrase at Volkswagen meant.
Profile PM Garage |
hollari Guest
01-08-2006, 14:52 Subject: Relay Explained: What Does It Do? (Image) |
Und welches (s. (Photo) ?!?
Hat vielleicht wer einen kompletten Schaltplan mit ALLEN Kerzen, Glüh-Relais u. Fuses?
Subjectively, the car feels different after the change.
It works much better with the large relay (at temperatures above +20 degrees Celsius).
If this is only for the coolant heating system, then...
I don't quite understand that...
| Description: |
| File size: |
151.92 KB |
| Viewed: |
6510 times |
Translated on 07-09-2026, 18:17.
02-08-2006, 13:33 Subject: Relay Explained: What Does It Do? (Image) |
It should still be connected to it and have a large 50A fuse nearby.
Translated on 07-09-2026, 18:18.
Profile PM Garage |
hollari Guest
02-08-2006, 20:26 Subject: Relay Explained: What Does It Do? (Image) |
Hmm.
Today, I briefly removed the light switch.
'I also removed the cover so you can see the fuses (photo) and relays.'
sees.
But it requires a 50A fuse and a 'larger' relay.
Unfortunately, I couldn't find anything.
I might take it apart again sometime, maybe I'll find something then.
Arne Guest
03-08-2006, 10:59 Subject: Relay Explained: What Does It Do? (Image) |
The component located in the bottom right corner (103) in your photo is likely the glow plug relay.
Arne.
Translated on 07-09-2026, 18:19.
hollari Guest
03-08-2006, 13:27 Subject: Relay Explained: What Does It Do? (Image) |
Aha.
Let's try to tap into this and connect an LED.
Translated on 07-09-2026, 18:20.
hollari Guest
22-09-2006, 14:10 Subject: Relay Explained: What Does It Do? (Image) |
Okay. That's correct.
I connected a wire from pin 85 and connected a button (to ground).
If I press that, it will 'light up' (you can tell by the interior lighting).
