Engine Control Unit (ECU) Location
Go to page: 1, 2  Next
stef
Post29-08-2006, 12:24    Subject: Engine Control Unit (ECU) Location Quote
hello
I'm looking for the fuse box on my Seat Alhambra (which is similar to the VW Sharan), but I'm not sure where it might be located.
Can you help?
Best regards from France.
stef
Translated on 10-09-2026, 5:40.
Back to top Profile PM Email
Herr Antje
Post29-08-2006, 12:56    Subject: Engine Control Unit (ECU) Location Quote
There are no stupid questions, only stupid answers icon_biggrin.gif.
Which control unit are you referring to?
Engine control unit:
As far as I know, behind the speedometer...
Comfort control unit:
under the driver's or passenger seat.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 10-09-2026, 5:41.
stef
Post29-08-2006, 13:10    Subject: Engine Control Unit (ECU) Location Quote
Okay, sorry, it's the engine control unit.
behind the speedometer?
Oh man, what a stupid place!
"Thank you very much, Stef."
Translated on 10-09-2026, 5:42.
lupo3ltdi
Post29-08-2006, 15:20    Subject: Engine Control Unit (ECU) Location Quote
yes, sorry, it's the engine control unit.
thank you very much, stef.
It's located behind the dashboard, but only in the older models. The newer ones have it in the engine compartment, behind the battery.
stef
Post29-08-2006, 16:47    Subject: Engine Control Unit (ECU) Location Quote
hello
Unfortunately, it's quite old, manufactured in 1998. I'm going to try to expand it now.
The problem is due to a code 65535, which indicates a loss of full power. Sometimes there is no power at all, and when I use VAGCOM, it shows that the boost pressure is only measuring at 639 millibars.
Okay, I will watch it.
best regards, stef
Translated on 10-09-2026, 5:43.
lupo3ltdi
Post29-08-2006, 17:02    Subject: Engine Control Unit (ECU) Location Quote
hello
'The problem is due to a code 65535, which indicates a loss of full power. Sometimes there's no power at all. When I use VAGCOM, it shows that the measured boost pressure is only 639 millibars.'
best regards stef
Remember to remove the mounting clip from the bottom. Otherwise, you'll scratch the glass of the speedometer by repeatedly sliding it in and out.
Translated on 10-09-2026, 5:44.
fr
Karma: +0 / -3   Thank you, like it!
Post29-08-2006, 18:27    Subject: Engine Control Unit (ECU) Location Quote
3. Write vague and uninformative titles like "I urgently need help!" and get upset if the moderators give your thread a more descriptive title. icon_wink.gif
Translated on 10-09-2026, 5:45.
stef
Post30-08-2006, 17:10    Subject: Engine Control Unit (ECU) Location Quote
hello TDI enthusiasts.
Okay, I'm at the control unit now, and I've removed everything (speedometer, etc.). Now, how do I disconnect the connector?
I saw a click on the side where the hose goes in, so I pushed it, but it didn't come out. I don't want to pull too hard, did I forget something?
It's really a stupid place to hide a device like that; you can barely reach the steering column because the handlebars are in the way!
Thank you for your help.
best regards, stef
Translated on 10-09-2026, 5:46.
Rudi
Post30-08-2006, 20:56    Subject: Engine Control Unit (ECU) Location Quote
Hello Stef,
The hose needs to be lowered, and then the latch needs to be placed over the hose connector.
be pushed aside (if necessary, with gentle force).
Rudi
Translated on 10-09-2026, 5:47.
stef
Post31-08-2006, 15:31    Subject: Engine Control Unit (ECU) Location Quote
Great, thanks, it worked perfectly!
The hose inside the device had a hole. I replaced the hose, and now the device is working again, without any error codes.
Just one last question, and it's not really related to the topic: When I read the values using VAG-COM, in one area, the required injector quantity is 42 mg/h, but the actual measured injector quantity doesn't exceed 35.2 mg/h.
Is this normal?
stef
and thank you for the great forum, it has really been helpful.
Translated on 10-09-2026, 5:48.
Rudi
Post31-08-2006, 17:28    Subject: Engine Control Unit (ECU) Location Quote
Which one limits it - torque (008 - 3) or turbidity (008 - 4)?
Translated on 10-09-2026, 5:49.
stef
Post05-09-2006, 12:39    Subject: Engine Control Unit (ECU) Location Quote
What do you mean, Rudi?
stef
Rudi
Post05-09-2006, 12:52    Subject: Engine Control Unit (ECU) Location Quote
If you look at measurement block 008 in the diagnostic tool (e.g., VAG COM),
Then, the first value indicates the speed (which is less important), and the second value indicates the quantity setting.
according to the accelerator pedal, the third is the amount allowed by the torque, and the fourth is...
the permissible amount based on the level of turbidity.
The lowest value indicates the actually possible injection amount.
'In your case, the reading was 42mg. My question is whether the reading of 35mg was obtained from sample 3 or sample 4.'
I'm guessing it's 4 (not enough air).
Rudi
Translated on 10-09-2026, 5:50.
stef
Post05-09-2006, 13:07    Subject: Engine Control Unit (ECU) Location Quote
ok I understand.
Okay, if I remember correctly, the last selected injection amount was somewhere between 42 and 45, and I believe the second one was the actual injection amount, always 35.2 at full throttle.
But I need to take a closer look at it.
sounds like a dying LLM?
I noticed that when accelerating fully, the LLM value goes up to 850, and then slowly decreases, staying between 800 and 850.
Okay, I will review everything carefully again.
Thank you very much for your help.
stef
Translated on 10-09-2026, 5:52.
Herr Antje
Post05-09-2006, 13:14    Subject: Engine Control Unit (ECU) Location Quote
If it's truly a Russian restriction, then compare the intended and actual values for LMM (lambda-max modulation) and the actual and intended boost pressure.
You can review log files as many times as you like afterwards, and you don't always have to physically drive.
Aktuell:
Translated on 10-09-2026, 5:53.
Rudi
Post05-09-2006, 14:09    Subject: Engine Control Unit (ECU) Location Quote
@Steff:
Which measurement block was that supposed to be?
Which tool did you use?
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KGE Installation Location at AKN Diesel Engine Technology
No new posts Relay Location Peugeot 206 Diesel Engine Technology
No new posts Coolant Thermostat Location 1Z Diesel Engine Technology
No new posts Temperature Sensor Location: Installation Guide Diesel Engine Technology
