Defective candle
windl
Post15-10-2002, 8:16    Subject: Defective candle Quote
'In my lantern, I suspect diesel is leaking out. Could it be that it's simply becoming leaky over time, or is something else the cause?'
Best regards, Windl
Post15-10-2002, 9:53    Subject: Re: Hot Chocolate Candle Leaking Quote
windl wrote:
...or is it something else?
Hello, that's what I mean. Because it's difficult to leak diesel from the light bulb. If I remember correctly, you have an engine with a distributor fuel injection pump -> Probably you mean the fuel injectors.
If the nozzle itself is leaking, the only solution is to replace it.
The connection to the fuel line can be adjusted, possibly a new fuel line will be needed.
First, check if the black, flexible hoses that connect the fuel injectors to the fuel return are leaking.
Hello, Rainer
joergs
Post15-10-2002, 13:33    Subject: Defective candle Quote
I can only agree. Last week I had a similar experience and was completely panicked. Then I looked closely and realized that the hoses were just coming loose. I replaced the hoses and dried out the light bulb, and that was it.
By the way, the hose is sold in meters, and each meter costs a hefty 11 euros, plus any additional noise! icon_redface.gif icon_twisted.gif
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B2 Achsmanschette undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leaky AVF AGR Valve: Causes & Fixes Diesel Engine Technology
No new posts ABS/ESP Leak: Find the Source! Diesel Engine Technology
No new posts ESP undicht / Dichtungen Diesel Engine Technology
No new posts Ölfilter undicht Diesel Engine Technology
