Seat Ibiza 110PS TDI: Upgrade to G3
Go to page: 1, 2  Next
cksIT
Post07-02-2006, 9:27    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
I have a few more questions again, hopefully someone knows something about icon_smile.gif.
"Was the SEAT Ibiza, manufactured in 1998 with 110 horsepower, also available with the AHF or ASV engine?"
or were all of those things actually "afn" back then?
As far as I know, the Ibiza's engine mounts are the same as the Golf 3's, so the engine swap would be quite straightforward. However, what about the catalytic converter? Would it fit?
4) Does the speedometer fit the G3 in terms of the connectors?
I remember that they were the same.
Thank you in advance for your efforts!
Translated on 04-09-2026, 8:40.
Post07-02-2006, 10:24    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Unfortunately, it's only vaguely related to 1).
Even the ASV in the 2000s 6K GP01 is mounted on all three original Golf 3 bearings.
So, I think they all fit the dimensions.
Oh, I'll add point 2 after all.
The catalytic converter looks very similar to the newer ones, with a long flexible pipe and a support bracket between the flexible pipe and the catalytic converter. As far as I know, it's a 038 model, which is what's used in the Golf 4.
I currently have that Ibiza "under my control." If you want to know more, I'll go check it out at my friend's place.
Translated on 04-09-2026, 8:42.
cksIT
Post07-02-2006, 10:38    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Don't stress about it...
I'll probably drive over in the evening to take a look. If they're on the 3rd layer, the spacing should be the same as in the G3.
I just found out that this tachometer fits, as some are being sold on eBay (suitable for G3, Ibiza, etc.).
How does the CAT (Compact Audio Transducer) work with the G4? Can you fit a CAT into the G3?
I'm just curious if there were other engine options available for the Ibiza.
"If it's an ASV or an AHF, I'll just leave it as is; it's too much hassle to register it. My TÜV (technical inspection) will complain about it, and I won't be able to get the necessary certificates for the engines..."
"Thank you in advance!"
Translated on 04-09-2026, 8:43.
Post07-02-2006, 10:47    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
I'm guessing it's the AFN engine, because Seat has kept that engine in production for longer than VW, and the AFN was even available in the Golf 3 Variant and Passat 3B in 1998.
Translated on 04-09-2026, 8:45.
cksIT
Post07-02-2006, 10:53    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Okay, then I'll stop by.
He said the turbo is broken, is it dangerous to drive with that?
If I had to, I would have it towed, since it's still running...
It would be amazing if that worked!!! Finally, a cool engine in that car icon_smile.gif.
especially because I'm currently having problems with my car...
Post07-02-2006, 11:13    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
"Turbo kaputt" can mean anything:
- Vacuum hose slipped off, and the user doesn't understand.
- U.Dose opened.
- VTG, stuck or seized.
(You can still drive this far, but no further.)
- Wave stuck.
(I wouldn't buy it from here.)
- Wave turned off, turbine blades hit -> parts enter the intake manifold, engine.
Translated on 04-09-2026, 8:46.
Boro
Post07-02-2006, 11:14    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
The 110 HP Ibiza models were only equipped with the AFN engine from October 1997 to August 1999; afterwards, they were equipped with the ASV engine.
The ASV was later included in the 6K Gp01, which is the facelift model, but it's still based on the 6K platform.
The speedometer from the Ibiza fits, but not everything works perfectly. The instruments themselves function, but the pin configuration seems to be different. As far as I know, the turn signals don't light up, and I believe the handbrake light also doesn't work. The Ibiza speedometers have the MFA (Multi-Function Display).
According to the ET catalog, this catalytic converter with the long flex pipe was only used in the Ibiza 110 HP models with the AFN and ASV engines. The catalytic converter itself is likely the same, but the mounting brackets or supports are different. I have an Ibiza, and the Golf 3 AFN catalytic converter doesn't fit on mine.
Translated on 04-09-2026, 8:48.
cksIT
Post07-02-2006, 11:46    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Can the KAT be relatively easily adapted, or is it completely different?
As long as multi-factor authentication (MFA) is working, I don't care about anything else; I'll adjust the PIN settings as needed.
Do these levers fit the Golf 3? Or do I need to buy the MFA lever separately?
@dieselmartinViewing profile: dieselmartin Why wouldn't you buy it then?
If parts had flown into the engine compartment, it shouldn't be working anymore, right?
First of all, a huge thank you for the help; it's not easy to figure all of this out on your own.
Translated on 04-09-2026, 8:50.
Post07-02-2006, 11:52    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Not engine compartment, but engine.
If the turbine blades have scraped against the housing, you can't be sure whether and how many parts have broken off (although you can usually see "if" it happened).
But what happened to the parts?
Are they just lying around in the swamp of LLK, and are they (for now) not causing any further harm?
Have they reached the combustion chamber, and are they diligently "polishing" the cylinder walls there?
The risk would be too high for me, because then the entire cost of the renovation might be wasted very quickly.
Translated on 04-09-2026, 8:51.
cksIT
Post07-02-2006, 12:17    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Okay, I meant the engine compartment. But if they were in the combustion chamber, it should be pretty obvious right away that it wouldn't fit. I wanted to test the compression; I'm getting a device with an adapter for the glow plugs.
Is that really that dangerous?
If the wave is still intact, then I'll get the... I'll immediately modify the turbo, and then it will fit perfectly.
Translated on 04-09-2026, 8:53.
Boro
Post07-02-2006, 12:48    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
I can't tell you exactly! I only noticed it while looking for a replacement part! I think BOSAL has an online catalog that contains images!
You'll definitely need an MFA (Multi-Factor Authentication) lever, otherwise you won't be able to switch!
cksIT
Post07-02-2006, 13:02    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
No, I wanted to know if I can take over the gear lever... the Ibiza has one, right?
Translated on 04-09-2026, 8:54.
cksIT
Post08-02-2006, 17:33    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
"My engine seems to be having a problem right now; it won't start at all, and there's white smoke coming from the exhaust, which looks like a blown head gasket."
I've found a Toledo now, manufactured in July 1997, with a 110 horsepower TDI engine.
"How about this: can it be transplanted into a G3 system just as easily?"
The Ibiza was completely rotten.
I'm assuming it's also an AFN.
It's really important because I need to pick it up as soon as possible.
"Thank you!!!"
Translated on 04-09-2026, 8:55.
Post08-02-2006, 17:51    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
It's really important, as I need to pick it up as soon as possible.
Sure, the best approach is to agree without seeing it and immediately offer double the requested amount icon_eek.gif.
Translated on 04-09-2026, 8:56.
cksIT
Post09-02-2006, 7:39    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
There was never any talk of attacking without warning.
"When I encounter something like that, I always start by connecting my laptop and thoroughly examining the engine."
But once again, it wasn't what I wanted.
By the way, you have to be quick when it comes to something like that, otherwise you definitely won't get the car.
Post09-02-2006, 9:01    Subject: Seat Ibiza 110PS TDI: Upgrade to G3 Quote
Sorry, I misread that.
I read "is really funny" as an ironic reference to the seller trying to pressure you. Just like they always do: "There are other interested parties," "it's best to come by today."
Translated on 04-09-2026, 8:57.
No new posts GKB Seat Ibiza 6L: 59.8kmh to 1000 Diesel Engine Technology
No new posts AFN Engine: Sudden Power Loss at 120-140 km/h On-Board Diagnostics (OBD)
No new posts Injector Differences: AHH 90hp vs. AFN 110hp Diesel Engine Technology
No new posts Ibiza: Where is the NTC water connection? Diesel Engine Technology
