Chip Tuning (ALH): Report & Questions
Sauger der 3-te
Post10-05-2006, 13:32    Subject: Chip Tuning (ALH): Report & Questions Quote
Hello, fellow diesel enthusiasts.
Yesterday, I had a new software installed on my Golf VI ALH, manufactured in 2002. The power was increased from 90 to 120 horsepower, and the torque was increased from 210 to 266 Nm.
Regarding the driving experience: It already feels incredibly powerful.
DZR times:
Original: 8.8 - 9.2 seconds.
Chip: 7.2 - 7.8 seconds (1460 kg with driver).
Beschleunigung 130-150 original: 15 Sek. Then, wait for 7-8 seconds.
After that, I logged the data using VAG.
According to the tuner, the boost pressure was increased by 0.25 bar.
Here are the logged values for MWB 11, with the engine at full throttle in 4th gear (while driving uphill):
TIME | Engine speed | Specified MAP | Actual MAP | D.cycle MAP
403.48 1344 1254.6 1275.0 39.8
404.68 1449 1948.2 1428.0 24.7
405.88 1596 1989.0 1825.8 39.8
407.08 1785 1989.0 2152.2 59.0
408.28 1953 1989.0 2335.8 74.1
409.48 2100 1989.0 2050.2 68.1
410.68 2247 1989.0 1897.2 64.9
411.88 2394 1989.0 1927.8 65.3
413.08 2499 1989.0 1917.6 63.4
414.28 2625 1989.0 1978.8 64.5
415.48 2730 1989.0 1989.0 64.1
416.68 2856 1989.0 1999.2 65.3
417.88 2961 1989.0 2009.4 65.7
419.08 3066 1989.0 2019.6 67.3
420.28 3171 1989.0 1989.0 68.9
421.48 3297 1989.0 1978.8 69.7
422.68 3402 1989.0 1978.8 70.5
423.88 3486 1989.0 1978.8 71.7
425.08 3570 1989.0 1968.6 71.7
426.28 3633 1989.0 1978.8 71.3
427.48 3696 1989.0 1989.0 72.1
428.68 3738 1989.0 1989.0 71.7
429.88 3780 1989.0 1989.0 72.1
431.08 3822 1989.0 1989.0 72.1
432.28 3885 1989.0 1978.8 72.1
433.48 3927 1989.0 1978.8 71.7
MWB 11 at idle:
0.34 903 1142.4 1009.8 24.7
1.54 903 1142.4 1009.8 24.7
2.74 903 1142.4 1009.8 24.7
3.94 903 1142.4 1009.8 24.7
MWB 8 showed.
TIME | Engine speed | I.Q. (Driver's required I.Q.) | I.Q. (via rpm/Torque) | I.Q. (via air mass)
404.28 1407 47.8 50.0 37.4
405.48 1554 48.6 51.0 39.4
406.68 1722 47.8 51.0 40.6
407.88 1890 47.2 51.0 40.8
409.08 2058 46.6 51.0 40.8
410.28 2205 46.0 51.0 40.8
411.48 2352 45.6 51.0 40.6
412.68 2478 45.2 51.0 40.2
413.88 2583 44.8 51.0 40.2
415.08 2688 44.4 51.0 40.2
416.28 2814 44.2 51.0 40.0
417.48 2919 43.8 51.0 39.8
418.68 3024 43.6 51.0 39.6
419.88 3150 43.2 51.0 39.6
421.08 3255 43.0 51.0 39.6
422.28 3360 42.8 50.8 39.6
423.48 3444 42.6 50.2 39.6
424.68 3528 42.6 49.8 39.6
425.88 3612 42.4 49.4 39.4
427.08 3675 42.2 48.8 39.0
428.28 3717 42.2 48.6 38.8
429.48 3780 42.0 48.2 38.6
430.68 3822 42.0 47.8 38.4
431.88 3864 41.8 47.4 38.2
433.08 3906 41.8 47.2 37.8
The LMM consistently delivered its target values (850 mg/R) up to 3700 U/min, after which it decreased.
(800 mg/day).
Sorry for this presentation.
My question is:
Why are the 0.25 bar LD (boost) values not visible in log MWB 11, and why has the target LD value at idle been increased to 1142 mbar?
Could this possibly be a poorly implemented (unprofessional, or 'fake' in programming terms) LD (luminance diffusion) enhancement?
What is your opinion on this tuning?
Borys.
Translated on 06-10-2026, 16:30.
Post10-05-2006, 13:41    Subject: Chip Tuning (ALH): Report & Questions Quote
Hm,
Indeed, that looks strange. The values don't match the tuner's output.
Where did you take the measurement?
A1 highway (towards the Moselle valley)?
Because 4000 in the 4th [place] is already quite fast.
In idle, the VTG is at its maximum value of "24.7%", and it is set to "CLOSED".
With a quick "slap," it should also create a significant overshoot... although it would also generate a lot of pressure, which is probably what the tuner was trying to achieve.
Setting the torque limit to 51 mg is RUBBISH. Because that's the pump's maximum, so it's effectively DISABLED, and the car will always run at the Russian border (referring to a maximum limit).
I'm not a tuner, but that looks like garbage.
Translated on 06-10-2026, 16:42.
Sauger der 3-te
Post10-05-2006, 13:53    Subject: Chip Tuning (ALH): Report & Questions Quote
Hello Martin,
It happened on a country road between Schweich and Föhren. I also didn't dare to turn the steering wheel any further; it was really fast.
There are also decent pressure boosters that can go up to 1.5 bar, and those existed even before the tuning. However, the LD (likely referring to a specific system or component) will quickly readjust.
Borys.
Translated on 06-10-2026, 16:44.
Post10-05-2006, 14:01    Subject: Chip Tuning (ALH): Report & Questions Quote
Can you still choose between "tuned" and "original"?
Then I would create diagrams showing how the manifold vacuum behaves when you apply original throttle versus what it does when it's tuned.
I personally find 1.5 bar to be quite high for a target of just under 1 bar.
Is your VTG definitely working correctly, and has it not been running with original software that has been limited (e.g., to 24.7% or 80-90%)? (I'm not sure right now what the PWM value is for the maximum downward regulation.)
I definitely wouldn't want to drive that software.
With the calibration, you'll also notice every single microgram less that the LMM delivers – precisely because you're constantly scraping against the Russian border.
Do yourself and others a favor and don't drive at full speed in the fourth gear on country roads – do it on the highway instead.
If you're driving as far as Foehren, you might as well get on the highway.
Translated on 06-10-2026, 16:45.
Sauger der 3-te
Post10-05-2006, 14:42    Subject: Chip Tuning (ALH): Report & Questions Quote
Hello Martin,
Unfortunately, the programming cannot be turned off.
MWB 11: Idle speed before chip tuning.
12.82 903 999.6 1040.4 24.7
14.02 903 999.6 1030.2 24.7
MWB 11, idle state, then.
When the VTG is initially set, it moves smoothly back and forth.
The overshoot disappears after 1-2 seconds.
The ones with 1.5 bar were intentionally over-pressurized.
Under normal acceleration, the pressure is approximately 1.25 to 1.35 bar.
Borys.
Translated on 06-10-2026, 16:48.
Post10-05-2006, 14:57    Subject: Chip Tuning (ALH): Report & Questions Quote
OK.
"Since the PWM value is 24.7 both before and after the tuning, it seems the controller (software) has a termination condition. Before the tuning, the actual value is too high, and after the tuning, it's too low."
if (IDLE) then VTG_CLOSED;
Standard swingers, up to 1.35 bar, already sound more realistic.
But that doesn't change anything about the constant border disputes with Russia.
Did you officially purchase the tuning?
If so, with whom?
Translated on 06-10-2026, 16:50.
Sauger der 3-te
Post10-05-2006, 15:02    Subject: Chip Tuning (ALH): Report & Questions Quote
Hi.
What do you mean by 'officially'? There's simply no record of it.
The software was developed by ****4***** programmers.
Borys.
Translated on 06-10-2026, 16:51.
Nebelwerfer_TDI
Post10-05-2006, 15:22    Subject: Chip Tuning (ALH): Report & Questions Quote
Maybe you could try using a different encoding method (with standard software) sometime.
Normally, the control unit still contains software versions for automatic transmission and 4Motion/syncro. These are used when employing a switchable tuning system.
You will likely get an error message (e.g., communication with the bus interrupted), but if you're lucky, it will work normally.
'I should try it out sometime this weekend with a manual transmission (with my automatic transmission, only the first gear is available in the 4Motion coding).'
Translated on 06-10-2026, 16:52.
Post10-05-2006, 15:54    Subject: Chip Tuning (ALH): Report & Questions Quote
Why are the 0.25 bar LD elevation values not visible in log MWB 11
It's quite simple: either the person who made the statement was mistaken, or the person who manufactured the chip didn't know how to increase the pressure to 0.25 bar.
That wouldn't have happened icon_cool.gif here in the shop.
Translated on 06-10-2026, 16:54.
Sauger der 3-te
Post10-05-2006, 17:27    Subject: Chip Tuning (ALH): Report & Questions Quote
Hello Rainer,
I originally wanted to have my car tuned by you, but it was too far away, and I didn't want to have the engine control unit removed or be without my car.
Well, next time it will definitely work. (New nozzles + performance stage 1).
What size injectors are you using for this tuning (ALH) - 0.205?
Is it possible to increase the boost pressure through programming in a way that wouldn't be detected during a dyno test?
As Martin already wrote, I'm driving near the Russian border.
Borys.
Translated on 06-10-2026, 16:55.
Post10-05-2006, 19:15    Subject: Chip Tuning (ALH): Report & Questions Quote
Sauger der 3-te wrote:
Is it possible to increase the boost pressure programmatically without it being detected during a logged drive?
Yes, but it doesn't really make sense, as it would be very complicated. Besides, you would be able to see it in your log even without the boost pressure reading.
Is that the logical consequence...?
Translated on 06-10-2026, 16:56.
No new posts Octavia RS TDI (BMN): Specs, Review & Questions Transmission, Chassis, Body & Interior
No new posts A few questions (I'm a diesel newbie) Questions about que... Diesel Engine Technology
No new posts Clutch Noise Gone: Report & Solution Diesel Engine Technology
No new posts Oil leak on PD-TDI: Report and analysis Diesel Engine Technology
