To implement this, a diagnostic system is required.
Modifications should only be made on these channels if a certain level of expertise is present. Due to extreme settings, engine damage may occur.
Not all tax equipment allows for these adjustments!
Select engine control unit.
For channels 1, 3, 4, and 5, please log in using the username "12233".
Select adaptation
Select the appropriate channel and change the value (can only be changed within certain limits).
Channel 1: Injection Volume
Channel 2: Idle Speed
Channel 3: Air Mass
Channel 4: Injection Timing
Channel 5: Starting Amount Tschüss
Michael II
