Engine Power Issues: Troubleshooting & Solutions
Martha
Post21-05-2006, 13:40    Subject: Engine Power Issues: Troubleshooting & Solutions Quote
Hello everyone,
The following problem occasionally occurs in my 1Z Passat 35i, and it only happens in cold weather:
1) At partial load, the vehicle attempts to briefly accelerate without any accelerator pedal input, then returns to its previous speed. The frequency is approximately 1 Hz.
2) Under full load (e.g., on a highway incline), there is a significant lack of power when using full throttle. If you briefly release the throttle and then press it again, acceleration resumes until a blockage occurs again, and the speed no longer increases. Repeating this process a few times allows you to increase the speed to a level appropriate for the 90 horsepower.
VAG-Com is not available. The workshop suspects the mass airflow sensor (MAF) is the cause.
Do you think this is realistic, or do we need to consider a different approach?
Martha.
Translated on 14-10-2026, 23:32.
Herr Antje
Post22-05-2006, 8:19    Subject: Engine Power Issues: Troubleshooting & Solutions Quote
It's possible, but the workshop should know for sure and not just guess! They should do a diagnostic test, or have it done. In my opinion (although I don't know much about the 1Z engine), it could also be an NHG issue...
Perhaps it's cheaper to buy your own VAG-COM diagnostic tool. Not every workshop necessarily has the expertise.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 14-10-2026, 23:34.
Post22-05-2006, 10:37    Subject: Engine Power Issues: Troubleshooting & Solutions Quote
Just try driving without the LMM, i.e., unplug it.
While the final speed might not be fully reached because the tractor will have less power, if it's the mass airflow sensor (MAF), the blockages should be gone (meaning there's nothing to "overcome"), and the surging should also stop.
Price: 0 EUR.
Result: Determining whether the 85 EUR for the mass airflow sensor is worth it.
Translated on 14-10-2026, 23:35.
kapernaum
Post23-05-2006, 7:11    Subject: Engine Power Issues: Troubleshooting & Solutions Quote
Hello!
Besides the LMM (mass airflow sensor), the boost pressure control valve (solenoid valve) could also be the cause.
Best regards!
Translated on 14-10-2026, 23:36.
Post23-05-2006, 7:27    Subject: Engine Power Issues: Troubleshooting & Solutions Quote
Not quite:
On the Passat, the N75 valve, also known as the turbocharger pressure control valve, is not located on the fender between the shock absorber and the mass airflow sensor (MAF). Instead, it's mounted on the firewall, near the brake booster.
A small manifold with three hose connections (blue, red, and black).
Translated on 14-10-2026, 23:37.
hollari
Post23-05-2006, 10:45    Subject: Engine Power Issues: Troubleshooting & Solutions Quote
Have you checked if there are any air bubbles in the fuel lines?
When was the diesel filter last replaced?
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
