Nebelwerfer_TDI wrote: |
| Why would a different encoding release more initial memory? |
Because the software allows for it in some datasets, the starting quantities for the individual codings can actually appear different.
As a result, for example, an engine that has been reconfigured for automatic transmission in a manual transmission vehicle can completely eliminate the usual cold-start problems.
A chip tuner could, for example, copy the "start quantity" parameter from the automatic transmission coding to the manual transmission coding. This would result in a good warm start without the problems associated with incorrect coding, such as permanent error messages or suboptimal engine behavior.
Don't ask me about the meaning of such original software... on that topic, I'll pass it back to Bertil
