dieselcruiser Guest
12-06-2006, 15:32 Subject: Diagnostic options for Smart CDI? |
What options are there for reading the error memory of a Smart ForTwo CDI, manufactured in 2001, yourself? Is there any software comparable to VAG-COM available, and also a suitable adapter that can be purchased? I haven't been able to find anything on eBay or anywhere else online.
Translated on 20-07-2026, 3:22.
denni Guest
12-06-2006, 21:42 Subject: Diagnostic options for Smart CDI? |
Maybe this will help you.
http://www.smart-forum.de/modules.php?op=modload&name=Forum&file=viewtopic&topic=42014&forum=19
Translated on 20-07-2026, 3:23.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
12-06-2006, 21:54 Subject: Diagnostic options for Smart CDI? |
For current Smart ForTwo CDI models (from 2003 onwards), VAG-COM can also be used.
However, things are likely to be worse with the 2001 model, as the engine control unit probably doesn't yet support the OBD2 protocol. This means that all other tools based on the OBD2 protocol will also not work.
Profile PM WWW Garage |
dieselcruiser Guest
13-06-2006, 12:12 Subject: Diagnostic options for Smart CDI? |
Thank you for the responses. I also received a rejection from obd-2.de regarding a diesel vehicle from 2001.
Translated on 20-07-2026, 3:24.
