ECU Software Update for ARL Engine?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post27-05-2006, 3:16    Subject: ECU Software Update for ARL Engine? Quote
Hello.
I read somewhere that there's a newer software version available for the ARL engine.
Part number | Previous data | New data
038 906 019 BH - 1587 + 1591 5630 (Sharan ASZ engine)
038 906 019 KG - 4900 + 5255 5342 (Golf / Bora with ARL engine)
038 906 019 LB - 4905 5101 (Polo ATD engine)
038 906 019 NJ - 6113 + 6412 7331 (Polo BLT Engine)
Where can I read the software version using VAG Com?
The following is displayed to me:
Controller: 038 906 019 FE
Component: 1.9L R4 EDC G000SG 1468 >>>> Is this the software version?
Coding: 00003
What is the new software supposed to achieve?
Can VW provide these updates? Or can this also be done with VAG Com?
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "with kind regards" or "best regards" in English.
Audi SQ5 8R Cvub
Translated on 28-09-2026, 7:08.
Back to top Profile PM Email
Post27-05-2006, 10:31    Subject: ECU Software Update for ARL Engine? Quote
Yes, '1468' is the software version. VW can update the software. Of course, it's useful to do so when there are errors, as these are essentially 'bug fixes'.
VAG-COM is a diagnostic tool and not a tool for flashing control units.
Translated on 28-09-2026, 7:10.
Ross-Tech-Support
Post27-05-2006, 10:48    Subject: ECU Software Update for ARL Engine? Quote
Software updates are specific to the control unit. In the case mentioned above, there is NO update available for part number 038 906 019 FE.
Translated on 28-09-2026, 7:11.
pa-mm6
Post27-05-2006, 11:35    Subject: ECU Software Update for ARL Engine? Quote
Ah ha.
Now I understand.
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Latest engine control unit (ECU) software for Audi A4 170 hp Diesel Engine Technology
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
No new posts Automatikschaltsoftware ändern?! Diesel Engine Technology
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
