Document: Severe oil leak at the cylinder head, AJM engine (Solution)
Michael II
Post08-10-2002, 14:37    Subject: Document: Severe oil leak at the cylinder head, AJM engine Quote
AJM, Pump-nozzle engine.
Significant oil leak at the cylinder head.
Cause:
The sealing ring between the tandem pump and the cylinder head, in the area of the ball valve, is deformed. Because the engine oil is under pressure in this area, the oil leak becomes noticeable after only a few kilometers.
Procedure:
Remove the tandem pump and install a new seal (part number 038 109 293).
and use part number 038 109 293 A.
Tighten the upper mounting screws to 20 Nm, and the lower mounting screws to 10 Nm.
Tschüss
Michael II
Translated on 08-07-2026, 17:54.
Ratings - Document: Severe oil leak at the cylinder head, AJM engine
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak V6 TDI: Causes & Fixes Diesel Engine Technology
No new posts VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Diesel Engine Technology
No new posts Performance Issues: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Golf 3 TDI: Excessive Smoke & Power Loss? Diesel Engine Technology
