ATF oil leak on 74 kW TDI engine (Solution)
Michael II
Post08-10-2002, 16:51    Subject: ATF oil leak on 74 kW TDI engine Quote
1.9 L / 74 kW TD
ATF oil leak due to a leaky oil line.
Cause:
Cracked ATF (Automatic Transmission Fluid) line connecting the automatic transmission to the cooler, caused by excessive bending stress.
Procedure:
Inspect the ATF (Automatic Transmission Fluid) lines from the transmission to the radiator in the front for leaks, and repair or replace them if necessary. Additional bracket No. 8A0 317 827 D with clamp.
Attach part number 4D0 317 171 and screw N 040 303.3.
Tschüss
Michael II
Ratings - ATF oil leak on 74 kW TDI engine
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI AWX Oil Leak: Causes and Solutions Diesel Engine Technology
No new posts Turbocharger Oil Leak: Causes & Fixes Diesel Engine Technology
No new posts Stop Oil Leaks: Repair & Prevention Diesel Engine Technology
This topic is locked, you cannot edit or reply. Oil Leak: AFN/Turbo Exhaust Problems Diesel Engine Technology
