G28 Encoder Position: Find & Troubleshoot
chaerte
Post04-08-2006, 10:09    Subject: G28 Encoder Position: Find & Troubleshoot Quote
I'm having the following problem:
I installed a V6 TDI (AFB) engine in my boat. The engine originally came from an automatic transmission vehicle. Now, I've installed a dual-mass flywheel from an AAH (V6 gasoline) engine. The starter motor from the TDI fits. I'm not using a clutch bell. The G28 sensor is mounted on a rail, allowing for continuous adjustment within a range of approximately 30° on the flywheel. The engine runs, but only after experimenting with the sensor's position. I just want to avoid damaging anything...
Question:
Does the engine control unit actually receive the signal from the sensor when the corresponding cylinder is at Top Dead Center (TDC)? icon_wink.gif Probably yes, otherwise the G28 probably wouldn't be named that way. } If that's really the case, I could rotate the engine to TDC and align the G28 with one of the six recesses in the dual-mass flywheel.
I just want to be on the safe side. Unfortunately, I haven't found anything suitable in any of the SSPs.
Here's a similar problem, but unfortunately, there's no solution either.
/viewtopic.php?t=10114&highlight=ot+geber
Translated on 09-09-2026, 21:32.
Post04-08-2006, 10:27    Subject: G28 OT Sensor Position: Troubleshooting & Guide Quote
chaerte wrote:
Does the engine control unit actually receive the signal from the sensor when the corresponding cylinder is at top dead center?
If your engine has the TDI-typical sensor disc with many teeth and 2 opposing gaps, this gap will not pass the sensor at the engine's top dead center (TDC)!
The "Lücke" (gap) likely marks the beginning of a calculation cycle, within which the motor's top dead center (TDC) occurs at some later point.
If you absolutely don't want to break anything, check on a normally installed engine where the sensor is located relative to the crankcase, and fix it in the boat at exactly this position.
Translated on 09-09-2026, 21:35.
chaerte
Post04-08-2006, 11:03    Subject: G28 Encoder Position: Find & Troubleshoot Quote
No, he doesn't just have two gaps.
The original clutch plate for the automatic transmission had 6 pins evenly distributed around its circumference. The flywheel had 6 corresponding recesses distributed around its circumference. I adjusted the G28 by swapping the two cables, according to the ELSA documentation. Does this method still work?
The sender is located in a different position in the AHH transmission compared to the AFB transmission. And unfortunately, it's impossible to take measurements once it's installed.
Translated on 09-09-2026, 21:36.
Post04-08-2006, 11:20    Subject: G28 Encoder Position: Find & Troubleshoot Quote
I might be able to take a look at the V6 TDI at the SSP tonight.
Here are some diagrams related to the G28. However, I'm not sure if they show the exact details or if they just provide a schematic explanation of how the measurements are taken.
Translated on 09-09-2026, 21:37.
chaerte
Post04-08-2006, 11:25    Subject: G28 Encoder Position: Find & Troubleshoot Quote
I have the SSP manual too. It doesn't really contain much information. But maybe other TDI SSP manuals do?
Translated on 09-09-2026, 21:38.
Post04-08-2006, 11:53    Subject: G28 Encoder Position: Find & Troubleshoot Quote
chaerte wrote:
The original clutch disc for the automatic transmission had 6 pins evenly distributed around its circumference. The flywheel had 6 recesses distributed around its circumference. I adjusted the G28 by swapping the two cables, according to the ELSA manual. Is this method still considered valid?
No idea, so I'll have to disconnect.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. NW position and connecting rod damage? Diesel Engine Technology
No new posts Position Temperature Sensor Transmission, Chassis, Body & Interior
No new posts Audi Navigation GPS Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Golf 4: Location of the boost valve Diesel Engine Technology
