dakoal Blaumann
Joined: 05/31/2005 Posts: 66 Karma: +5 / -0 Location: Hausleiten
16-06-2006, 6:14 Subject: G4 AI Upgrade: G3 Conversion, DZM Signal Instability |
Hello everyone.
I installed a Golf 4 TDI instrument cluster in my "small" naturally aspirated diesel engine.
Except for the frame and the fuel gauge, everything else is working.
Among other things, there were also problems with the tachometer signal.
Since the 1Y/AAZ engine receives the tachometer signal from the alternator (LIMA), it wouldn't be compatible.
I then took the signal from the "glow plug timer control unit" (simply connected it to pin 1 of the control unit). The tachometer shows the correct RPM, but...
Under full load, the engine speed (RPM) exhibits uncontrolled fluctuations up and down. Since the ESP has a "full load valve," I suspect that a voltage fluctuation or something similar occurs when I accelerate.
Could an electrician perhaps have an idea of what could be done to address these fluctuations?
I would be grateful for any help.
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 19-09-2026, 1:01.
Profile PM Email |
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
16-06-2006, 9:03 Subject: G4 AI Upgrade: G3 Conversion, DZM Signal Instability |
I always thought that, even with TDI engines, the tachometer signal came from the alternator.
I don't remember off the top of my head whether it's still processed by the engine control unit.
I've also completed the upgrade, and everything is working fine for me.
Is that the AI from the 4-series, and is it powered by a diesel engine?
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 19-09-2026, 1:03.
16-06-2006, 17:27 Subject: G4 AI Upgrade: G3 Conversion, DZM Signal Instability |
I was wrong; of course, the speed pulse in the TDI engines comes from the MSG  .
Sorry, but I can't help you with the problem regarding the speed/revolutions per minute.
Gruss Oliver.
Translated on 19-09-2026, 1:04.
dakoal Blaumann
18-06-2006, 10:40 Subject: G4 AI Upgrade: G3 Conversion, DZM Signal Instability |
Hello.
After the entire engine started jumping in sync with the tachometer, I disconnected the cable from the glow plug control unit. Unfortunately, the engine still "stuttered" under partial load afterwards.
I've now expanded the GZSTG. I'm going to build the frequency divider based on the instructions in the g3 forum, and I'll take the tachometer signal from the alternator (LIMA).
Besides, my little Golf is running better than ever without the GZSTG  . So, the electronics are completely messed up, which is also why the tachometer is jumping around.
dakoal
Translated on 19-09-2026, 1:05.
Profile PM Email |
dakoal Blaumann
18-06-2006, 16:09 Subject: G4 AI Upgrade: G3 Conversion, DZM Signal Instability |
Since it was too hot outside to do anything, I took the GZSTG apart in the basement and replaced the blown electrolytic capacitor. Now there's a clean DZM signal at pin 1. Also, the Golf now works the same way with the GZSTG connected as it does without it, so it must have been defective for quite some time.
dakoal
Translated on 19-09-2026, 1:06.
Profile PM Email |
