Speedometer Calibration: Accurate Speed Reading
Bolzer
Karma: +14 / -0   Thank you, like it!
Post20-06-2006, 11:02    Subject: Speedometer Calibration: Accurate Speed Reading Quote
Hi.
A friend wants to install larger wheels on his T4. According to the TÜV (German technical inspection authority), he needs to adjust the speedometer. Is this possible with VAG-COM? If so, which channel? Or is it a mechanical adjustment?
I won't receive the bus data until tomorrow.
Best regards, Bolzer.
Translated on 27-08-2026, 1:44.
dakoal
Post20-06-2006, 14:30    Subject: Speedometer Calibration: Accurate Speed Reading Quote
on http://wiki.ross-tech.com/
"It's about the 'coding number for the momentum transfer number'."
Simply use GPS to test which one fits best.
During my upgrade from a G3 to a G4 AI, I adjusted the wheel speed factor in the G4 tachometer, and now it displays the correct value.
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm //www.spritmonitor.de/image_116461_1.png
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 27-08-2026, 1:45.
Back to top Profile PM Email
Bolzer
Post25-06-2006, 6:49    Subject: Speedometer Calibration: Accurate Speed Reading Quote
Hi.
Thanks for the help. It worked. I changed the AI setting to match the wheel circumference of the 2.8-inch tires. Now the speedometer shows a higher reading than it should.
Translated on 27-08-2026, 1:46.
mullemaus
Post25-06-2006, 10:38    Subject: Speedometer Calibration: Accurate Speed Reading Quote
Some AIs (like G4 V6, or was it VR?) even provide direct assistance when you hover the mouse cursor over the relevant field in the adaptation channels.
It's not the device itself icon_wink.gif that's the problem, but the VAG-COM version. icon_wink.gif Not all versions, or all distributors, are the same. Rainer, for example, has a performance measurement feature integrated, which Andy Vetter's version doesn't have. }
Translated on 27-08-2026, 1:47.
Nebelwerfer_TDI
Post26-06-2006, 7:32    Subject: Speedometer Calibration: Accurate Speed Reading Quote
It's not the device itself that's the problem, but the VAG-COM version. Not all versions, or all distributors, are identical.
aha...... So, my version provides KI direct assistance for a G4 V6, but not for my 3B. Or could it be because I was logged into KI with the V6 (using the login that I can't find anymore icon_mad.gif)?
Rainer, for example, also integrated a performance measurement, which Andy Vetter's system does not have .
Yes, unfortunately - I should have also bought mine from Rainer icon_rolleyes.gif.
Translated on 27-08-2026, 1:48.
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Speedometer: G3 Impulse Calibration Adjustment Diesel Engine Technology
No new posts A4 Dashboard (Instrument Cluster) Replacement? On-Board Diagnostics (OBD)
No new posts Program Car Speedometer: Easy Guide Diesel Engine Technology
