Hello everyone,
I made changes to the adaptation of channel 1 (MSG) using VAG-Com.
I adjusted the "ori" value, sometimes increasing it and sometimes decreasing it... unfortunately, I didn't [note what I did].
I was concerned that my tuning box might
affect the value.
Now, even after resetting to the "default" setting (with the device connected), I am still not getting full performance.
Is it enough to just disconnect the device and then re-enter and save the values, or is there a way to reset the MSG (with the device disconnected) to the factory settings?
Okay, it's a 2002 Octavia with an ASV engine (81 kW TDI).
