What is this part called?
80_b4_tdi
Post06-07-2006, 23:50    Subject: What is this part called? Quote
Hello everyone!
Can someone please tell me what this part is called?
See image.
 File size:  45.05 KB
 Viewed:  1911 times
Audi 80 B4
Bj. 1993
1,9TDI mit 90PS
370000 Km auf der Uhr.
Translated on 30-08-2026, 3:27.
Back to top Profile PM Email
Golfosaurus
Karma: +9 / -0   Thank you, like it!
Post07-07-2006, 0:42    Subject: What is this part called? Quote
Charge air pipe, pressure pipe, connecting pipe - the latter term is used by VW for the part with the number 028 145 840A.
2007 - ???: Tiguan Sport&Style TDI 4Motion, Mkb. CBA
2006- 2007: G4 Variant TDI Sport Edition Mkb. ASZ
2000-2006:G3 TD Mkb. AAZ
Nebelwerfer_TDI
Post07-07-2006, 8:12    Subject: What is this part called? Quote
It must be around the year 1992-1994, and it still has the pump with the potentiometer sensor.
Intake manifold?! It's also called intake manifold pressure...
Translated on 30-08-2026, 3:28.
80_b4_tdi
Post07-07-2006, 12:03    Subject: What is this part called? Quote
"Connecting pipe" is also what Audi calls it... and it's available for a reasonable 80 euros. And since you can hardly find this part at any junkyard, I guess I'll have to pay for it.
Thank you all!
Audi 80 B4
Bj. 1993
1,9TDI mit 90PS
Post07-07-2006, 12:27    Subject: What is this part called? Quote
Why?
What's the matter?
Cavities?
For 80 EUR, I would first buy "UHU Stabelit Ultra" or "endfest 300" (or whatever it's called) and fiberglass fleece, and apply it with adhesive. It's fun and saves money.
The adhesive only hardens completely when exposed to heat.
endfest 300 (formerly known as Stbelit ultra, about 20 years ago)
http://www.uhu.de/produkte/test_prod_cons/produktansicht/index.php?auswahlKategorie=5&artikel_id=10&sprache_id=1
Translated on 30-08-2026, 3:29.
Nebelwerfer_TDI
Post07-07-2006, 13:52    Subject: What is this part called? Quote
Or you could recreate it using stainless steel pipes, exhaust pipes, along with welding equipment and a cutting tool... that way, it will at least last a long time.
Translated on 30-08-2026, 3:30.
No new posts Golf 1K: Why is the Golf VI called that? Transmission, Chassis, Body & Interior
No new posts BMR Valve: Function and Purpose Explained Diesel Engine Technology
No new posts Does this control unit fit? On-Board Diagnostics (OBD)
No new posts How to Read This Control Unit (ECU) On-Board Diagnostics (OBD)
