Bolzer Blaumann
14-09-2005, 20:47 Subject: Polo 6N: Mysterious Electrical Problems |
Hi.
A friend of mine has a 1996 Polo 6N with engine code AEX. This Polo has two very strange problems that I've been trying to fix for the past 3 years.
"Every year, around April, smoke comes out of the steering column, but only once. Unfortunately, I've never been able to witness this phenomenon myself. There are no signs of burning, and all the switches and brushes, etc., are in good condition. I've also heard of another Polo that exhibits the same problem, but no fault has been found in that case either."
2. The interior lighting. The main interior lights are switched off, but the speedometer illumination remains on. Everything else is off. All switches and bulbs are off, only the speedometer is still illuminated. If you repeatedly toggle the light switch 5-10 times, it usually turns off. However, it can also happen that the speedometer refuses to turn off. As soon as you remove the key, the speedometer also turns off. I have also already replaced the light switch, but it didn't work. Again, this doesn't always happen, but quite often. However, I haven't seen it happen in person, as my car always worked properly.
Unfortunately, the errors don't seem to be related, as the first one has been present since she's owned the car, while the second one only started appearing in the last 6 months.
I hope someone recognizes these errors and can help me.
Best regards, Bolzer.
Translated on 10-10-2026, 15:13.
matthiasTDI96 Profi-Schrauber
15-09-2005, 7:59 Subject: Polo 6N: Mysterious Electrical Problems |
Okay, it's probably not the light switch itself, but the thought of smoke is concerning. Since only a few components are likely to be the cause, it's best to disassemble and check everything (turn signal switch, slip rings, ignition switch, wiper switch). Otherwise, I didn't have similar problems with my AEX. Did the 1996 model already have the illuminated speedometer, or was it still the type that was lit from the front?
Translated on 10-10-2026, 15:15.
Cheffe Blaumann
15-09-2005, 9:37 Subject: Polo 6N: Mysterious Electrical Problems |
Regarding your problem with the smoke coming from the steering wheel area, I can tell you that in my case, the turn signal switch was the cause of the issue. You might want to take a closer look at that.
cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
15-09-2005, 9:38 Subject: Polo 6N: Mysterious Electrical Problems |
The smoke is normal; the dust on the grinding wheel will burn off. It's the same with the G3. Just clean it thoroughly and that's it.
"The speedometer issue is also a mystery to me, but if it starts happening as soon as you turn the key, then everything seems to be in order."
Translated on 10-10-2026, 15:16.
Bolzer Blaumann
15-09-2005, 11:48 Subject: Polo 6N: Mysterious Electrical Problems |
Hi.
Okay. The issue with the dirty slip rings might be possible. Since it only smokes slightly once a year. But why always at the same time of year, and it always happens even when there's no load on it?
The issue with the tachometer lighting is quite strange. There must be a short circuit somewhere in the wiring.
Translated on 10-10-2026, 15:17.
15-09-2005, 17:07 Subject: Polo 6N: Mysterious Electrical Problems |
Regarding the lighting technology: Since my former 1997 AEX Polo still had the version with the illuminated interior lights, the 1996 model might have been the same. In my opinion, the changeover occurred around 10/1997 or so.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 10-10-2026, 15:18.
cksIT Blaumann
16-09-2005, 7:17 Subject: Polo 6N: Mysterious Electrical Problems |
I'm not sure, maybe it's too cold in the winter, so it doesn't start to ferment. Then, as soon as it gets warm, it starts fermenting for several months. In the summer, it might ferment a little bit all the time, so you wouldn't even notice. (If the car is in the sun, it can get quite warm inside.)
However, it's just an idea. But I definitely know of several people who have experienced the same thing with their Polo or Golf 3.
Translated on 10-10-2026, 15:19.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
16-09-2005, 9:10 Subject: Polo 6N: Mysterious Electrical Problems |
cksIT wrote: | | The smoke is normal; the dust on the grinding wheel will burn off. It's the same with the G3. Just clean it thoroughly, and that's it. |
I've also seen this smoke in the G3 occasionally. However, I don't think it's coming from the slip ring, because if it were, it would only happen under load, like when honking the horn, which definitely wasn't the case for me.
From a technical perspective, it seems unlikely that the slip ring (or the grease-dirt mixture) should produce smoke without any load.
It always happened with me when I turned on the ignition, which is why I suspect the ignition switch. There are also currents flowing through it that are high enough to cause dirt to burn off, resulting in the corresponding smoke.
Guste.
Translated on 10-10-2026, 15:20.
Profile PM Garage |
Bolzer Blaumann
13-10-2005, 12:52 Subject: Polo 6N: Mysterious Electrical Problems |
Hi.
I found the problem with the tachometer lighting. It's a faulty car radio. The radio is supplying 12V at the lighting connection, even though it should only be receiving power for the button illumination. As soon as the ignition key is removed, the radio turns off, and so does the light. It's actually quite simple, once you know what's wrong.
I also replaced the windshield wiper switch once. Let's see if that stops the smoking now. It was already a bit stiff.
Bolzer.
Translated on 10-10-2026, 15:22.
13-10-2005, 13:04 Subject: Polo 6N: Mysterious Electrical Problems |
Great!
Thank you for the feedback.
Profile PM Garage |
31-08-2009, 18:49 Subject: Strange Smoke Behind Steering Wheel: What to Do? |
Hello everyone,
*a large mountain dust road*
"Today, while at work, I was backing out of my parking space. I straightened the steering wheel and started to drive away when I noticed a small puff of smoke rising from behind the steering column – essentially, just like the various posters described in this old thread."
I immediately noticed the misfire, steered the car to the side of the road without engaging the clutch, and first observed what was happening. The smoke stopped immediately when I turned off the ignition, and it didn't seem like it was going to return. I checked everything without using any tools, but found nothing (all fuses were okay, no smoke under the dashboard...). With the door open, I cautiously turned the ignition back on - everything seemed fine. I waited a while, then carefully drove home. There, I removed the steering column cover and searched for a long time - I found nothing. A complete check of all control units was also unsuccessful (I suspected the semi-automatic climate control system might have a burned-out actuator, but the actuator test ran without problems). The only thing that smelled a little strange was around the ignition switch, otherwise everything seemed okay and functional.
"Does anyone have any further thoughts on what might be causing this, beyond what's already been discussed above? The previous suggestions seem to imply it's a minor issue, like just dust on the contact rings (although I doubt that, as the horn wasn't engaged) or a switch burning out. The ignition switch could very well be a likely culprit (8 years of city driving... the engine at least shuts off after a very small rotation)."
At least, finding this thread gives me a little peace of mind... let's see if there are any new insights about it.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 10-10-2026, 15:24.
31-08-2009, 21:40 Subject: Polo 6N: Mysterious Electrical Problems |
guste100 wrote: | | (...) which is why I tap the ignition switch. There are also currents flowing through it, which are high enough to cause any dirt to burn off, accompanied by the corresponding smoke. |
My assumption from 2005 was confirmed in early 2008.
"In my case, three years after the initial post, the ignition switch actually failed. However, the starter motor then stopped working (while the ignition still turned on)."
The smoke occasionally reappeared over the years (perhaps 10-20 times within those years).
Anecdote:
If you need to replace the ZAS (Zündausfallanzeige/ignition failure indicator), use an original VW part. The part from the aftermarket was already defective upon purchase. The S contact and ignition were working, but the starter contact was not. However, this was already my problem before the replacement, so I initially doubted my own sanity (especially since it started perfectly fine with a jumper wire connected to the ZAS).
Guste.
Translated on 10-10-2026, 15:28.
Profile PM Garage |
31-08-2009, 22:14 Subject: Polo 6N: Mysterious Electrical Problems |
Quote: |
The smoke appeared sporadically over the years (perhaps 10-20 times within those years).
If I were to look at our problems in a more general way, I would say that I'm still relatively calm... because this was definitely the first time this has happened.
Have you disassembled the faulty switch to investigate the cause?
The symptoms you're describing (ignition works, starter doesn't) strongly suggest a problem with the starter contacts, which are likely the most heavily loaded components (I have no idea how much current the solenoid draws, but it's probably quite a bit). The ignition system itself still has the X-relay. Perhaps the smoke actually came from the attempted starting, and you just noticed it a bit later...
Was the initial contact completely lost immediately, or had it already been showing signs of trouble during the previous launch attempts (besides the smoke)?
Perhaps I should check the course availability just in case, so I can still enroll if necessary... or maybe I should just switch it to "start" mode right away.
Regarding the original part, that's clear in this kind of situation... but I want to first observe how things develop - it only happened once so far.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 10-10-2026, 15:31.
Octavia_4x4 Schrauber
01-09-2009, 10:14 Subject: Polo 6N: Mysterious Electrical Problems |
In vehicles like the VW Golf III, Ibiza 6K, Polo 6N, Polo 6N2, and Ibiza 6K GP01, the steering column controls are often the source of the problem.
"They are identical in construction for all models except for the steering column mounting. Dirt and grease on the copper contacts can burn off under load, which can cause smoking."
With a bit of luck, that will be it. But with a bit of bad luck, the steering column lever might not work properly later.
Translated on 10-10-2026, 15:33.
01-09-2009, 12:44 Subject: Polo 6N: Mysterious Electrical Problems |
Ibiza1986 wrote: | | In the Golf III, Ibiza 6K, Polo 6N, Polo 6N2, and Ibiza 6K GP01, the steering column levers are often the source of the problem. |
"In my opinion, the smoke should only appear on the steering column controls when they are actively being used, such as when turning on the turn signals or windshield wipers. However, in my case, the smoke appeared even when these functions were not being used."
Jan6k wrote: | | Did you dissect the faulty switch to investigate the cause? |
No, just throw it away. But upon closer inspection, the plastic seems to have become slightly soft.
Jan6k wrote: | | Did the contact with the launch vehicle suddenly disappear, or had it already been showing signs of failure in the previous launch attempts (besides the smoke)? |
It started to become apparent towards the end, as it occasionally required turning the key multiple times before the starter motor would engage.
Jan6k wrote: | | Maybe I should check the course registration | just to be sure, so I can still enroll if necessary... Jan6k wrote: |
You can check the cable colors in the usual software. But there aren't that many thick cables connected there, so you can figure it out with just a few combinations at any time (and since there's no ground wire, you don't have to worry about a short circuit).
| or just convert it to a start button...}
*Whispering*: I had two 2.5mm² cables with exposed ends dangling from underneath the panel for quite some time. Basically, as an emergency jump-start solution. *Speaking louder*: But it's really a sloppy job, because the ignition switch isn't protected, in my opinion.
Guste.
Translated on 10-10-2026, 15:35.
Profile PM Garage |
01-09-2009, 16:29 Subject: Polo 6N: Mysterious Electrical Problems |
Same here. Additionally, my turn signal switch is only being loaded with around 50...100 mA instead of the usual several amperes.
Quote: |
No, just throw it away. But upon closer inspection, the plastic seems to have softened a bit.
I will take a closer look at that again over the weekend. Today, everything worked perfectly on all the starts, without any issues.
Quote: |
It became apparent towards the end, as it occasionally required turning the key multiple times before the starter motor would engage.
So, with a warning... to get to the cable, to replace the switch, or perhaps to install a button.
Quote: |
*Whispering*: I had two 2.5mm² cables with exposed ends dangling from underneath the panel for a while. As a kind of emergency jump-start. *Speaking louder*: But it's really a sloppy job, because the ignition switch isn't protected, in my opinion.
It's good to know... I need to take a look at this on my Polo-SLP. The only thing that bothers me about the button idea is the lack of a reset protection. With a normal switch, this is usually done mechanically, not electrically. So, you'd need to figure out a way to achieve that, but it probably wouldn't be too difficult with a relay and a little bit of circuitry (following a scheme where switching from "on" to "off" would cause the relay to disengage, effectively disabling the switch until power is restored).
Jan.
1Z5 CFHF  / AHB H4D
Translated on 10-10-2026, 15:39.
