Reset Engine Control Unit (ECU) After DIY?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
vel_tins
Post13-07-2006, 23:20    Subject: Reset Engine Control Unit (ECU) After DIY? Quote
Hello everyone,
I made changes to the adaptation of channel 1 (MSG) using VAG-Com.
I adjusted the "ori" value, sometimes increasing it and sometimes decreasing it... unfortunately, I didn't [note what I did].
I was concerned that my tuning box might icon_rolleyes.gif affect the value.
Now, even after resetting to the "default" setting (with the device connected), I am still not getting full performance.
Is it enough to just disconnect the device and then re-enter and save the values, or is there a way to reset the MSG (with the device disconnected) to the factory settings?
Okay, it's a 2002 Octavia with an ASV engine (81 kW TDI).
Translated on 21-09-2026, 22:22.
Jochen_145
Post15-07-2006, 22:23    Subject: Reset Engine Control Unit (ECU) After DIY? Quote
Hello.
A faulty sensor might only distort sensor readings; it doesn't interfere with the control unit's regulation process.
Therefore, any changes you make with VAG-Com are initially independent of the auxiliary module (since only target values are being modified).
If your car has no power after resetting it to the original values and then connecting it to the module, it's likely the problem is with the module itself, or you may not have actually saved the original values.
Translated on 21-09-2026, 22:24.
vel_tins
Post16-07-2006, 8:29    Subject: Reset Engine Control Unit (ECU) After DIY? Quote
Yes, I had entered the default value (32768) again... however, it may not have been saved. icon_question.gif
Okay, so I disconnected the device, entered the value 32768 into all the modified channels again, saved everything, and took it for a test drive. It's working again, then I reconnected the device and everything is okay.
I do have one more question: If I save the value "000" for adaptation channel "0", shouldn't all the other channels be reset to their factory settings?
Translated on 21-09-2026, 22:25.
Rudi
Post16-07-2006, 9:35    Subject: Reset Engine Control Unit (ECU) After DIY? Quote
Radio Eriwan... In principle, yes - all adaptation channels (that learn the control unit themselves).
Since your TDI doesn't have those adaptation channels, nothing will happen. icon_wink.gif
Rudi
Translated on 21-09-2026, 22:26.
vel_tins
Post16-07-2006, 12:36    Subject: Reset Engine Control Unit (ECU) After DIY? Quote
Radio Eriwan... In principle, yes - all adaptation channels (which the control unit learns itself).
Since your TDI doesn't have those adaptation channels, nothing will happen. X
Oh, so only the "self-taught" ones... I thought you meant "everyone."
learned something new again icon_razz.gif.
"Please provide the text you would like me to translate from German to English."
Translated on 21-09-2026, 22:27.
No new posts Doku, n.löschb. Fehler im MotorsteuergerÀt 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM-Sollwert nach oben setzen nicht möglich Diesel Engine Technology
No new posts Dataset of engine control unit, customizable Diesel Engine Technology
No new posts Engine Control Unit (ECU) No Communication After VW Update Diesel Engine Technology
No new posts MotorsteuergerÀt 600 km nach Austausch Injektoren defekt On-Board Diagnostics (OBD)
