Golf/Bora 1.9L; 85 kW TD-PD 4-Motion.
Hub worn out in the clutch disc.
Cause:
Torque transmission from the engine to the gearbox. The external teeth of the hub on the clutch disc are completely worn out.
Such damage typically occurs after a short period of operation and only in conjunction with a significantly increased misalignment between the engine and the transmission.
Instead of a cable holder designed for 4-Motion vehicles, a cable holder intended for front-wheel-drive vehicles might be installed, which can cause complications during transmission installation.
Procedure:
Before installing the transmission, check the area around the engine.
attached cable holders. If a twist is detected, the part must be replaced with part number 06A 971 845 L.
Tschüss
Michael II
Translated on 05-07-2026, 12:39.
