Xenon ALWR Controller Unit
Maxx1278
Avatar-Maxx1278
Post20-07-2006, 12:44    Subject: Xenon ALWR Controller Unit Quote
Hello everyone!
Does anyone have a Golf IV or Bora with xenon headlights (manufactured from 2002 onwards) where the control units are located on the headlight housings themselves?
If so, what number should this control unit have?
I purchased headlights from e*** with a production date of 03/03 (from a car involved in an accident) and also installed them.
Now I have a problem because neither of the two ALWR steam turbines is responding.
I'm a little suspicious that one of the ECUs has no sticker on it, and the other has a sticker without a VW part number and a production date of 05/02.
I suspect that the control units were installed from a different vehicle.
These will not fit into the diagnostic system of the Golf IV.
Is that even possible?
Okay, I retrofitted the axle sensors with a wiring harness.
I have checked the voltage and wiring.
It seems everything is fine.
Please help!
"Thank you!"
Best regards.
Maxx.
Translated on 19-08-2026, 16:25.
Fireball
Post21-07-2006, 10:56    Subject: Xenon ALWR Controller Unit Quote
Are you aware that the xenon control units have nothing to do with ALWR?
Translated on 19-08-2026, 16:27.
Maxx1278
Avatar-Maxx1278
Post21-07-2006, 12:26    Subject: Xenon ALWR Controller Unit Quote
Fireball wrote:
Are you aware that the xenon control units have nothing to do with ALWR, right?
With the headlights produced from 2002 onwards, it's actually icon_smile.gif.
The ballast and the control unit of the ALWR are housed in a single enclosure.
A picture of something like that:
http://team-dezent.fimanist.com/XenonSTG.jpg
Translated on 19-08-2026, 16:28.
Fireball
Post22-07-2006, 14:29    Subject: Xenon ALWR Controller Unit Quote
Wow... I guess that falls into the category of 'something new learned.' Thanks.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ALWR Functionality: How It Works Transmission, Chassis, Body & Interior
No new posts ALWR (A6,4B '98): Engine Control Unit Problems On-Board Diagnostics (OBD)
No new posts ALWR sensors with (quasi) potentiometer output Electrical Systems, Vehicle Electronics, Multimedia
No new posts Headlight Failure Monitoring FIS A3 8P On-Board Diagnostics (OBD)
