SDI vs. TDI Injectors: Are They the Same?
Boro
Post20-07-2006, 12:08    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
I'm looking for a new fuel injector with a needle lift control for my AFN engine. The VW part number for this is 028 130 201 S.
You can find an injector nozzle for the 1.7 SDI VW Polo under the same designation in the Bosch online catalog.
Could it be that these nozzles are the same? The Bosch part number is different, but the VW part number is identical.
Translated on 21-10-2026, 9:36.
Nebelwerfer_TDI
Post20-07-2006, 12:14    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
but the VW number is identical.
If the part number matches according to AKTE, then they are the same. It's also possible that, due to simplified inventory management, VW combines parts with minor differences (or parts that are interchangeable).
I don't understand why the 1.7 SDi needs the 0.205 injectors from the AFN, especially considering its low cylinder filling.
Translated on 21-10-2026, 9:37.
Post20-07-2006, 12:41    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
... and if you were to dissolve those two Bosch codes?
Perhaps there was a typo there.
I find it very hard to believe that an AKU 205 has nozzles.
Translated on 21-10-2026, 9:38.
Post20-07-2006, 12:44    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
Hm ???
The Ecat database does not contain any information regarding the Bosch part number 0 432 193 744.
Only AFN, AHF, AVG.
Translated on 21-10-2026, 9:39.
Nebelwerfer_TDI
I find it very difficult to imagine that an AKU 205 has nozzles.
A higher proportion of homogeneous mixture would be the only explanation. However, the poorer atomization would argue against this. This further distances the AKU (Advanced Combustion Unit) from a smoke-free lambda=1 (which is, in any case, an unattainable goal for diesel engines - at least for now).
Post20-07-2006, 12:45    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
The AKU 1.7 SDI has...
0 432 193 680 and 0 432 193 682
The 1.9 SDI with 64 horsepower also has it.
Translated on 21-10-2026, 9:40.
Boro
Post20-07-2006, 13:28    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
The nozzle has the Bosch part number 0 432 193 707 and is intended for the AHG engine code! According to the Bosch online catalog, the equivalent part number is 028 130 201 S.
Translated on 21-10-2026, 9:41.
Post20-07-2006, 13:36    Subject: SDI vs. TDI Injectors: Are They the Same? Quote
As I mentioned, I strongly suspect there's a typo in the BOSCH database.
Because if you search *forward*, meaning using AFN or AHG, you will never get the result that the nozzles are the same.
The ...202 S is installed in the 1.7 SDI AKU engine, while the 1.7 SDI AHG engine is supposed to have the ...201 S (from the AFN).
I think someone probably mistyped "1 instead of 2" when entering the AHG code, and that makes it much more meaningful.
Translated on 21-10-2026, 9:42.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injector 0434250071 - Buy Now! Diesel Engine Technology
No new posts Injector Removal: A Hard Case Diesel Engine Technology
No new posts Question about the injector/injector seat Diesel Engine Technology
No new posts Honda Accord Injector: 2.0TD, 1997 Model Diesel Engine Technology
