Motor Electronics Failure Due to Heat
gtdpower
Post29-06-2003, 22:19    Subject: Motor Electronics Failure Due to Heat Quote
I have a Golf 3 AFN TDI, and since this extreme heat has been occurring recently, the electronics in my car have been malfunctioning. This manifests itself as follows:
- The engine stalls while idling at a red light when starting to move, and it won't restart for several seconds (it cranks without any response).
- Recently, the engine has also been cutting out while driving (which is not fun), and it takes a long time to restart.
Does anyone have any ideas? Has this issue been encountered before? (I couldn't find anything using the search function.)
Best regards, Nico.
Translated on 23-09-2026, 19:34.
Andy
Post29-06-2003, 22:23    Subject: Motor Electronics Failure Due to Heat Quote
Please search for relay 109 icon_idea.gif.
Andy.
Translated on 23-09-2026, 19:35.
Gerrit
hi
Have you ever inspected the famous relay 109? Is it possible that a break in a solder joint is the cause of the problem, and you're attributing it to heat (perhaps coincidentally?)
Good luck!
Back to top Profile PM Email
DocSnydor
Post30-06-2003, 12:01    Subject: Motor Electronics Failure: Heat Issues Quote
It would also sometimes take several seconds to restart.
Yo, I agree with my predecessors. I can confirm this from my own experience. Once, it stopped working for me in the middle of the city, right in the middle of an intersection icon_redface.gif.
And it was Saturday afternoon, just before 4, and only ATU was still open (but of course, they didn't have it icon_evil.gif).
Translated on 23-09-2026, 19:36.
Dj Ninja
Karma: +1 / -1   Thank you, like it!
Post21-07-2006, 21:12    Subject: Motor Electronics Failure Due to Heat Quote
I'm curious to know if this damned relay 109 has finally been discontinued and replaced with a semiconductor circuit in newer engine generations.
I've had this problem even in my customized VW bus. I pulled out the relay, stuck a piece of wire in there, and managed to get home. Then I put in a new relay, and everything was okay again. Let's see how long it lasts...
Translated on 23-09-2026, 19:37.
Post22-07-2006, 0:47    Subject: Motor Electronics Failure Due to Heat Quote
"I haven't installed these... complicated 109 relays in my T3 TDI. Instead, I installed a simple, robust relay from Bosch! No problems with it! You just need to modify one connector so that the simple relay can be activated."
Translated on 23-09-2026, 19:38.
Dj Ninja
Post22-07-2006, 1:11    Subject: Motor Electronics Failure Due to Heat Quote
I was thinking about using a large MOSFET and a driver circuit instead, since mine stopped working. Let's see, maybe I'll try that again.
No new posts TDI BKS Engine: Troubleshooting Electronic Issues Diesel Engine Technology
No new posts Starting problem in hot weather Diesel Engine Technology
No new posts Golf 5 1.6 FSI Fuel Problems in Heat Gasoline Engine Technology
No new posts Bremsenkraftverstärker setzt aus Transmission, Chassis, Body & Interior
