RS TDI wrote: |
My friend has a Cupra TDI...
Does it make a difference if he installs this transmission from the 130 HP TDI engine? |
Yep, that's what many Cupra drivers dream of.
However, you'll need to find an older transmission (called "FSM" in the 9N Polo), as the newer ones from the 130 hp models are only slightly longer than the one from the Cupra, making the effort not worthwhile.
With consistent Autobahn driving, the longer gear ratio probably won't noticeably reduce fuel consumption, but the (theoretical / downhill) maximum speed increases to over 240 real km/h
Quote: |
Can it handle the performance???
He should have around 200 horsepower and 400 Nm of torque... |
The basic construction of the gearboxes is the same, so it should work.
