Remove the fuel sender
bastion
Karma: +6 / -1   Thank you, like it!
Post06-08-2006, 15:18    Subject: Remove the fuel sender Quote
How do I remove the fuel level sensor from my car?
A4 Avant 08/01 AWX 05/08-
Translated on 07-07-2026, 23:41.
makrospex
Post06-08-2006, 17:56    Subject: Remove the fuel sender Quote
The temperature gauge is located in the suction pipe inside the tank.
First, remove the mat from the trunk, and then you'll see the fuel tank lid (secured with 3 screws). Remove the lid, and underneath you'll find the fuel filler neck with the hose connections for the diesel supply and return lines, and the connector for the fuel level sensor.
First, disconnect the hoses (otherwise diesel will leak out or air will get in) and detach the connector. Then, loosen the fitting around the intake manifold (sometimes you can loosen the threads with gentle taps from a hammer or screwdriver) and carefully lift it slightly, tilt it, and pry it out.
The fuel level sensor (float on an L-shaped wire) is attached to the suction pipe.
Assembly in reverse order.
Make sure not to confuse the inlet and outlet (the latter is thinner), and connect them securely with good clamps, otherwise the ESP may suck air from the direction of the tank.
Don't waste too much time when closing and connecting the hoses, otherwise there will be quite a bit of air trapped inside.
macro
Translated on 07-07-2026, 23:42.
bastion
Post06-08-2006, 21:35    Subject: Remove the fuel sender Quote
Okay, I'll get started on the work tomorrow.
Translated on 07-07-2026, 23:44.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts External temperature sensor and tank level sensor disconn... On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Color for upstream and downstream at the tank sensor? Diesel Engine Technology
No new posts A4 2.0 TDI Germany: Runs poorly during regeneration + fue... Diesel Engine Technology
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
