Steering wheel is loose, wobbles
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
makrospex
Post25-07-2006, 10:13    Subject: Steering wheel is loose, wobbles Quote
I had a flat tire on the right front side a few months ago due to a pothole that was covered by new snow. Since then, the steering wheel has been wobbly with the road bumps, and the car either pulls slightly to the left or right. When driving straight, the steering wheel is slightly tilted to the left. If I am standing on the curb in a light traffic lane, the steering wheel turns over 45° to the left.
Last week, the steering arms and heads were replaced in the workshop (they were also damaged), and an wheel alignment (at the alignment stand) was performed. Unfortunately, the symptoms described above remained, however, the straight-running stability improved, meaning the steering wheel no longer pulls as much as before, and by the way, the tires are evenly worn. Now, the steering wheel only tilts when the car is on the edge of the road, not like before when I would drive over a thick, freshly painted zebra crossing with a tire.
The ÖAMTC (Austrian ADAC) inspected the vehicle on the vibration platform yesterday, but the technician was unable to find anything wrong.
What could be the cause of this?
All the rubber bushings look OK. Why does the steering wheel still seem a bit crooked after the wheel alignment?
Greetings,
macro
Post25-07-2006, 10:44    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
Das schiefe Lenkrad ist schnell zu erklaeren.
1. Die Vermesser haben es nicht neu aufgesteckt. (vielleicht weil sie Angst vor dem Airbag hatten)
1b. sie haben es falsch aufgesteckt.
2. Es laesst sich nicht gerade aufstecken, weil die Verzahnung ja nur "schritte" erlaubt, die Einstellung der Spur aber "stufenlos" zu machen ist.
Mein Trekker ist seit der Erneuerung der Querlenker Gummis wesentlich resistenter gegenueber Spurrillen geworden. Die Erneuerung nach 220 Tkm war auch kein Luxus, sondern notwendig.
m,
Herr Antje
Post25-07-2006, 10:56    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
Achvermessung hat bestimmte Toleranzen. Öfters ist es so, dass man das Lenkrad nicht ganz gerade bekommt, dann muss einfach die Vermessung (auf Garantie) nochmals vorgenommen werden.
Jenach breite der Reifen ist ein ziehen im Lenkrad bei zB Spurillen normal. Ich wurde nur nochmal neu vermessen lassen, vielleicht ändert es sich zum positiven.
@dieselmartinViewing profile: dieselmartin
Lenkrad neu aufstecken ist eine Bastellösung (wieweit man das Lenkrad drehen kann ändert sich). Richtig vermessen tut man ohne das Lenkrad zu demontieren!! Faule Prüfen (wie ATU) stecken das Lenkrad kurz um (wenn kein Airbag vorhanden), weil es schneller geht wie vermessen. Das der Wendekreis sich ändert, ist denen ja egal. Wieviele Kunden werden das überhaupt bemerken icon_evil.gif
EDIT:
Da ich nicht weiß was für ein Fahrzeug, kann ich nicht sagen ob es ein Vorspur zum einstellen gibt. Wenn ja, auch mitmachen lassen. Kann auch ein Ziehen verursachen, vorallem aber beim bremsen.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Post25-07-2006, 11:03    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
@ Antje
Beim G3 und wohl auch spaeter mag das stimmen (das hab ich uebersehn)
Beim Golf2 (den ich zog mal hab vermessen lassen) MUSS das so sein, weil nur ein Spurstangenkopf verstellbar ist. Der andere ist aufgepresst. Daraus ergibt sich, dass das Lenkrad nicht "geradestellbar" ist, wenn die Spur stimmen soll.
Wenn man 2 verstellbare Koepfe hat, stimmts natuerlich, dass es geht und Lenkrad umstecken als Faulheit gesehn werden kann.
Herr Antje
Post25-07-2006, 11:30    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
dieselmartin wrote:
@ Antje
Wieder etwas gelernt icon_smile.gif Ich hatte in die Jahren, dass es der GII gab nichtmal ein Führerschein. Wo ich dann meine erste Fahrzeuge gekauft habe, hat es mir nicht für ein deutsches Fabrikat gereicht (Nissan Micra ca '83 und Mazda 323 ca'84). Beide hatten beidseitig verstellbare Spurstangenköpfe (der Mazda sogar hinten unabhängige Radaufhängung, die deutsche Marken voraus??).
Ich hatte aufjedenfall bis heute noch nie davon gehört, dass es soetwas überhaupt gab icon_redface.gif
Aktuell:
christians
Post25-07-2006, 12:35    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
Das war mir in so auch neu, allerdings wurde der GII z.T. sogar ohne Zeituhr verkauft, so eine Art Sondermodell "Sparta".
Gruß Christian
Rudi
Post25-07-2006, 13:10    Subject: Steering wheel is loose, wobbles Translating...
Sondermodell 'Sparta'.
Neben der Uhr fehlte auch noch die Mittelkonsole (bequemstes Durchsteigen!).
Dafür Kunstlederbezüge in schwarz! Im Sommer heiß, im Winter kalt (meine damalige
Flamme war permanent am maulen) aber extrem Pflegeleicht...
lg Rudi
Post25-07-2006, 14:15    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
Yeah !!!
Golf 2 C - ich hatte auch einen. Und hab fuer 92 Mark die Mittelkonsole nachgeruestet !
Daher weiss ich den Spass mit den Stangen.
makrospex
Post25-07-2006, 17:39    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
Meine Reifen sind 205 breit, nichts aufregendes.
Die Winterreifrn sind 195er, trotzdem ist eigentlich im Lenkradverhalten kein Unterschied auszumachen gegenüber den Sommergummis.
Naja, ich werd meine Bedenken bei der Werkstatt äussern und sie 'bitten' die Spureinstellung zu überprüfen und ggf. zu korrigieren (Bei Lenkrad Stellung 0°).
Ein Beispiel zum Kippen:
In Wien gibts ein paar Stellen, da sind ca. in Reifenabstand zwei karierte Streifen auf die Strasse gummiert. Ist jetzt schwer zu beschreiben aber es sieht ca. so aus als ob man aus einem Schachbrett zwei Streifen mit je zwei Feldern Breite herausschneidet. Die hellen Felder stehen dann also 1-2mm raus, muss man sich vorstellen. Jetzt sind die erhöhten Felder (Seitenlänge ca. 30cm) so angebracht, dass in Reifenabstand gegenüber ein niedriges Feld ist.
(Ich hoffe das versteht auch jeder jetzt)
Wenn ich da genau drüber fahre, wackelt mein Lenkrad genau 8 mal schnell hin und her, folgt also genau den Erhöhungen (von wenigen mm). Der Lenkradausschlag ist ca. 5° auf jede Seite!
Wenn ich mit der rechten Seite der Vorderachse auf einem Brett (2cm dick) stehe, steht das Lenkrad schon 30° nach links.
Das kann jetzt aber nicht wirklich an der Spureinstellung liegen, oder?[/list]
BM
Avatar-BM
Post25-07-2006, 19:19    Subject: Steering wheel is loose, wobbles Translating...
[Translating...]
Die Vorderachse kann man nur dann beurteilen, wenn ein vernünftiges Messprotokol vorliegt, auf dem sich alle messbaren Grössen befinden, auch wenn es darüber keine Werksangaben gibt.
Gib mal Daten deines Fahrzeugs und Messprotokol. Dann kann man weitersehen.
Leider gibt es immer noch zu viele Achsspezies, die in Wirklichkeit garnicht wissen was sie tun.
Möglich wäre es, das evt. Querlenker oder Achschenkel, bzw. das Federbein oder auch der Ahskörper (je nach Fahrzeug) was abgekriegt hat und man hat versucht, das zu kompensieren.
Wenn z. B. der Gesamtwinkel eines Federbeins nicht mehr stimmt, verändert sich auch der Lenkrollradius, bzw. die Grösse des Störkrafthebels, wodurch links und rechts dann unterschiedliche Kräfte in die Lenkung einwirken.
Wenn nach der Vermessung das Lenkrad mehr als ein halber Zahn aus der Mitte steht, ist das für mich ein Indiez einer Falschmessung (z.B. Felgenschlagkompensierung nicht durchgeführt).
3B5 AJM
No new posts Doku Lupo 6X1 MJ 2002, Vibrationen im Lenkrad Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wobbly Steering Wheel When Braking? Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Dito! Bremsen 1000 KM neu,Lenkrad schlägt vor und zurück Transmission, Chassis, Body & Interior
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Ibiza 6L Fahrersitz wackelt Transmission, Chassis, Body & Interior
