VTG Adjustment for BMW E39 530d with M57 D30 engine
onclebenz
Karma: +0 / -2   Thank you, like it!
1987 Mercedes-Benz SL Class
Post31-08-2006, 11:34    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
Hello!
How is the variable valve timing (VTG) system implemented in a BMW E39 530d with an M57 D30 engine?
Just like at VW, I feel a sense of pressure...
Onclebenz
Translated on 10-07-2026, 8:42.
Nebelwerfer_TDI
Post31-08-2006, 12:15    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
Okay, try disconnecting the hose while the engine is idling and holding your finger over the end; you'll feel it then. Or, trace the hose to see where it branches off.
Does the BMW 3.0d already have an electric actuator, just like the V10 TDI?
Translated on 10-07-2026, 8:43.
Post31-08-2006, 12:35    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
electric actuator, such as the one in a V10 TDI engine?
and the 3.0 CR TDI icon_smile.gif.
Translated on 10-07-2026, 8:44.
Nebelwerfer_TDI
Post31-08-2006, 12:44    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
and the 3.0 CR TDI .
Ah, so he's already...
It's a shame that it's so hard to find, because it would be interesting to take apart icon_smile.gif.
Translated on 10-07-2026, 8:45.
onclebenz
Post31-08-2006, 13:13    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
Nebelwerfer_TDI wrote:
Go ahead and disconnect the hose while the engine is idling, and hold your finger on it; you'll feel the difference. Or, trace the hoses to see where they branch off.
Hat der 3,0d von BMW denn nicht schon den elektrischen Steller, so wie der V10 TDI?
icon_rolleyes.gif I'm addressing BMW mechanics who can answer that specifically icon_arrow.gif.
Nebelwerfer_TDI
Post31-08-2006, 14:47    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
I'm addressing BMW mechanics who can answer that specifically.
You won't find many people like that here! And anyone who doesn't have two left hands, or can't tell the difference between a VTG loader and one from a cheap manufacturer, should also be able to figure out how it works.
I already gave you instructions for that icon_exclaim.gif. Look here -> Now, disconnect the hose while the engine is idling and hold your finger on it; you'll feel it then. Or, trace the hoses and see where they branch off.
und Hat der 3,0d von BMW denn nicht schon den elektrischen Steller, so wie der V10 TDI?
You can easily identify an electric scooter...
You can, of course, also call the diesel development department at BMW in Graz and ask to be connected to Mr. Ing. Steinparzer. He can answer your question specifically icon_wink.gif.
Translated on 10-07-2026, 8:47.
onclebenz
Post31-08-2006, 16:19    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
You won't find many people like that here! And anyone who doesn't have two left hands, or can't tell the difference between a VTG loader and something from a waste disposal company, should also be able to figure out how it works.
und
icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif
THANK YOU.
Translated on 10-07-2026, 8:49.
onclebenz
Post04-09-2006, 17:36    Subject: Used BMW 530d for sale Quote
Okay, I was able to work on the problem on Saturday.
The VTG (Variable Turbine Geometry) system operates similarly to Volkswagen's system, using vacuum and a solenoid valve.
The travel of the vacuum sensor's plunger was initially only about 2-3 mm, and the linkage felt quite stiff.
After several attempts to operate the rod manually, approximately 5 mm of lift could be achieved.
icon_question.gif How much pressure should the system normally have at the pressure sensor icon_question.gif?
Regards, Onclebenz.
Translated on 10-07-2026, 8:50.
mullemaus
Post04-09-2006, 21:55    Subject: VTG Adjustment for BMW E39 530d with M57 D30 engine Quote
For VW chargers, it's approximately 1 cm. icon_wink.gif I think this value should be transferable.
Translated on 10-07-2026, 8:51.
Herr Antje
Post05-09-2006, 6:08    Subject: Re: VTG Distribution BMW 530d Quote
onclebenz wrote:
The pin of the vacuum diaphragm was initially only about 2-3 mm in diameter, and the linkage was quite stiff.
It doesn't matter how much is "normal" at this point. Restoring mobility through movement isn't a long-term solution anyway. I would disassemble and clean the variable transmission gearbox (VTG). Then you'll have some peace for a while.
I think a 5mm hub is very/too small, especially because it will likely make the valve train (VTG) even more prone to sticking, just like with VW.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 10-07-2026, 8:52.
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts Webasto Heater BMW 530d E39 On-Board Diagnostics (OBD)
No new posts VTG Adjustment: Check and Calibration Diesel Engine Technology
No new posts VTG adjustment or cleaning of the loader? Diesel Engine Technology
No new posts VTG Adjustment Problems: AKN Engine Fix Diesel Engine Technology
