Funny Brake: Troubleshooting & Repair Guide
Karma: +805 / -0   Thank you, like it!
Post19-03-2006, 20:56    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
"Since Friday, I've been experiencing some strange behavior with the brake pedal: when you press the pedal firmly while the car is stationary, it slowly starts to sink, reaching approximately 80% of its travel."
While driving, you don't really notice it because you can achieve full braking power even with less pedal force.
Interestingly, the effect is not really reproducible; sometimes, nothing sinks at all.
Brake fluid is not lost.
Does anyone have any ideas? Could there be a leak somewhere in the master cylinder, or is a seal failing?
The car is a 1998 Audi A3 TDI.
Translated on 26-08-2026, 20:05.
BM
Avatar-BM
Post19-03-2006, 21:45    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
Does anyone have any ideas about this? Is there a leak somewhere in the master cylinder, or is a seal failing?
Actually, you've already answered the question yourself, considering how much brake fluid you're displacing. What's puzzling me is that defective rubber boots usually only allow a very small amount of brake fluid to pass through, and the problem appears sporadically.
Have you already read the ABS fault memory?
Is the ABS system free of air?
Otherwise, seal the brake line connections of the master cylinder with appropriate blind plugs and perform another pressure test.
3B5 AJM
Translated on 26-08-2026, 20:07.
BM
Avatar-BM
Post25-03-2006, 13:38    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
@ Rainer
Have you noticed anything about the brakes yet?
I'd be interested to know where the problem lies, because these vehicles are starting to get old.
3B5 AJM
Translated on 26-08-2026, 20:08.
Post25-03-2006, 13:41    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
The error is gone again. I suspect a small piece of debris or splinter that occasionally gets stuck in an unfavorable position.
I won't switch [to a new part] until the problem is constant; otherwise, I'll just install a new [component] myself, and three days later, that pesky piece of debris will find its way back in again...
I haven't read the ABS error codes yet, but it's working perfectly. icon_mrgreen.gif
Post27-04-2006, 16:49    Subject: Software Update: Latest Version & Features Quote
Now it's happening: the brake fluid is leaking out the back of the brake caliper – the aluminum sealing ring has corroded.
An HBZ has also been newly ordered.
Brilliant from Audi: the sealing rings aren't sold individually, but only as a set with a new brake line. They seem to fail frequently.
Translated on 26-08-2026, 20:09.
Post08-05-2006, 8:46    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
Brief feedback after replacing the rear brake hoses (connection between brake line and brake caliper).
The lines connecting to the brake caliper are sealed with aluminum sealing washers, which have simply corroded away. This has caused the brakes to become air-bound, and later, brake fluid has also leaked out from those connections.
It seems Audi is aware of the problem. New brake hoses were in stock, and the new ones have stainless steel (or at least they appear to) sealing washers instead of aluminum.
Translated on 26-08-2026, 20:10.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post22-03-2007, 22:15    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
Thanks, Rainer. Is that an aluminum gasket between the hose and the saddle?
Could you post a picture of that old thing? Then I can get a better idea of what it looks like.
derteileklaus
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 26-08-2026, 20:12.
BM
Avatar-BM
Post23-03-2007, 17:18    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
Could you please post a picture of the old thing?
Forgot your glasses? Take a look at the date.
3B5 AJM
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post24-03-2007, 15:59    Subject: Funny Brake: Troubleshooting & Repair Guide Quote
'icon_redface.gif' Wore glasses 'icon_redface.gif'.
the blind one-armed parts klaus
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo Adjustment Rod: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Comic resonance oscillation at idle Diesel Engine Technology
No new posts VAG-COM: Strange Values on Audi A4 (1995) On-Board Diagnostics (OBD)
No new posts Strange Noises During Operation and Load Changes Diesel Engine Technology
