MFA Activation: Possible on Dashboard?
PrivatBereich
Post15-10-2002, 12:55    Subject: MFA Activation: Possible on Dashboard? Quote
I accidentally discovered a (at least for me) new function on my instrument cluster icon_redface.gif while playing around: Turn the ignition on, press and hold the distance button, turn the ignition off, turn the ignition on again, and release the button.
Then, by pressing the trip button again, I can query eight different data points, including, under point 5, a test of all the LCD elements. I noticed that when doing this, the six arrows below the tachometer also become visible, which are normally only found on vehicles with the Multifunction Display (MFA). However, my Golf does not have an MFA.
Now that I can already see the arrows, the question arises for me whether the MFA (Multifunction Display) function of the instrument cluster can be activated via adaptation channels (or directly through the instrument cluster itself).
Then, I would only need to buy a wiper switch with MFA functionality, and I could at least display my consumption. For the outside and oil temperature, I would then need to retrofit the sensors. I could definitely do without the printed symbols icon_biggrin.gif.
Does anyone know anything about retrofitting MFA without a control unit replacement? icon_question.gif Is the function I 'discovered' already known, or is it something for the knowledge base? icon_exclaim.gif
For those who are interested in all the data:
1: 3813 (Momentum number?)
2:1
3: 32253
4: 4
5: Test of all LCD segments.
6:0
7: Current speed (or RPM).
8: 6.6 Trip (no idea what this is, it's not my current odometer reading).
You can access these values by briefly pressing the distance button. A number will appear for about two seconds, and then the value will be displayed until the ignition is turned off or the button is pressed again.
My car is a 1997 Volkswagen Golf 3, as indicated in my profile.
Hoping that you can shed some light on this for me...
-Private
Translated on 29-10-2026, 4:53.
Post15-10-2002, 18:54    Subject: Bad Cards: Strategy & Tips for Winning Quote
Hi.
"On my 1997 Golf (even without the MFA), a specific cable is already missing from the wiring of the engine control unit, which is necessary for the MFA to receive the engine speed and fuel consumption signal."
That means, even if I were to install the hardware, it wouldn't work.
Translated on 29-10-2026, 4:56.
DocSnydor
Post16-10-2002, 8:38    Subject: MFA Activation: Possible on Dashboard? Quote
'Aren't the sensors for engine oil temperature and outside temperature also missing? You don't have those without the MFA (Multi-Function Display), right? And without the Climatronic system as well?'
Translated on 29-10-2026, 4:57.
Michael II
Post16-10-2002, 10:59    Subject: MFA Activation: Possible on Dashboard? Quote
There are also various combination instruments...
Tschüss
Michael II
No new posts Software error in the instrument cluster - workshop action Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel to Gas Gauge Cluster Swap: Possible? Diesel Engine Technology
No new posts GRA Activation Not Working? Troubleshooting Guide. Diesel Engine Technology
No new posts Cruise Control Upgrade for VW T5: Unlock Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts GRA Error After Activation? Troubleshooting Guide. On-Board Diagnostics (OBD)
