AGR Valve: Location & Removal Guide
ollli
Post30-08-2006, 20:06    Subject: AGR Valve: Location & Removal Guide Quote
Hello fellow mechanics.
Where is the AGR valve disconnected on the AFN 81 kW engine? I would like to disconnect it before installing the engine.
I would appreciate a response.
Olli.
Translated on 02-09-2026, 4:07.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post30-08-2006, 22:22    Subject: AGR Valve: Location & Removal Guide Quote
use the search function, as this has been addressed many times before: https://community.dieselschrauber.org/en/viewtopic.php?t=9458&highlight=agr+deaktivieren
am besten m.W. Stainless steel sheet.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts AGR disconnected Diesel Engine Technology
No new posts Emergency mode after disconnecting EGR valve on a 2.0 DTI... Diesel Engine Technology
No new posts 1Z Max Pressure 1500 mbar, Control Valve Blocked Diesel Engine Technology
No new posts Passat 3C: Battery disconnected - now errors On-Board Diagnostics (OBD)
