Joined: 04/12/2002 Posts: 18046 Karma: +791 / -0 Location: St.Gallen 2018 Volkswagen T6
23-04-2021, 11:24 Subject: Extended Measurement Channels for VCDS via UDS |
In VCDS, it is possible to load and save sets of extended measurement values.
It is planned to create meaningful compilations on this topic, so that users of VCDS can save themselves from time-consuming searches in the channels, which can contain hundreds of measurement values.
If someone has already made similar collections, it would be great to post them here!
Best regards, Rainer
Profile PM WWW Garage |
Herbert Profi-Schrauber
dieselschrauber likes this. |
23-04-2021, 17:26 Subject: Extended Measurement Channels for VCDS via UDS |
Do you mean the files that are stored in the /Scaling directory, i.e., the usable files in the *.u01 format?
23-04-2021, 17:40 Subject: Extended Measurement Channels for VCDS via UDS |
Exactly
Ste.Bo likes this. |
27-04-2021, 19:33 Subject: Extended Measurement Channels for VCDS via UDS |
Hello
Unfortunately, they only allow the storage of the logged UDS values.
So far, it appears that the channel numbers are universally applicable, but not all are present in every device.
Please find the following files for logging purposes.
| Description: |
| Erweiterte Messwerte per UDS. |
 Download |
| File name: |
Benzin - Performance.u01 |
| File size: |
89 Bytes |
| Downloaded: |
414 times |
| Description: |
 Download |
| File name: |
Diesel - Luft, Begrenzungen.u01 |
| File size: |
71 Bytes |
| Downloaded: |
515 times |
