VAG-COM Data: Interpretation and Analysis
Dauerschrauber
Post23-08-2006, 17:50    Subject: VAG-COM Data: Interpretation and Analysis Quote
After my post from this afternoon was deleted without any comment, I'm trying again.
Just one more time. If a moderator believes that I am violating a policy in that regard, then...
If I have said or done something offensive, please let me know.
Hello everyone,
After repeatedly experiencing problems with my V6 TDI engine (AKN, Passat 3B), I have...
I borrowed a VAG-COM device from an acquaintance and started experimenting with it.
And already, the first questions arise (yes, I've already watched the general documentaries about it).
(read):
The TDI-Graph module tells me that my ignition timing is significantly retarded.
outside the tolerance range). Could this be related to the timing belt replacement that was done a few thousand kilometers ago?
Does having a turbocharger mean it can no longer reach its top speed? Immediately after the change, it was...
The engine was definitely properly adjusted at the VW dealership, but I wonder if it can readjust itself.
adjust?
When monitoring the "Air intake temp." (yes, I have installed the US version 6.07), it shows...
The intake air temperatures are always close to the outside temperature. When the car is stationary, it increases.
langsam an, im Fahrbetrieb liegt sie gerade mal 1-2 Grad über der Außentemp. D"as" is indeed.
It's quite nice, but I don't think my liquid cooler can cool it that well; it's probably more of a...
Sensor broken, right?
"The error log always shows an error: 'CAN gateway: incorrect encoding' (identified as code 00005)."
Kann man den Wert irgendwie umsetzen, damit dieser Fehler verschwindet? Does he even...?
It seems to be working fine, and everything appears to be functioning correctly (e.g., the multifunction display, CD changer, etc.).
Matthias.
Translated on 08-10-2026, 19:10.
mullemaus
Post23-08-2006, 19:18    Subject: VAG-COM Data: Interpretation and Analysis Quote
After repeatedly experiencing problems with my V6 TDI (AKN, Passat 3B), I borrowed a VAG-COM from a friend and started experimenting with it, and the first questions are already arising (yes, I have already read the general documentation for it):
Just one more time: If a moderator believes that I am violating a policy, then...
If I have inadvertently offended or stepped on someone's toes, please let me know...
It's probably because the Vag-Com license is not transferable. Strictly speaking, from a licensing perspective, this is not legally okay. To advertise something like that is quite problematic. icon_wink.gif In this case, your acquaintance will probably have to provide you with the necessary support. icon_wink.gif
Translated on 08-10-2026, 19:14.
Karma: +807 / -0   Thank you, like it!
Post23-08-2006, 19:40    Subject: VAG-COM Data: Interpretation and Analysis Quote
Well, you shouldn't be quite so strict about it. He didn't demand support from the manufacturer (Ross-Tech), he simply asked a normal question.
There's actually nothing against it. For now, it doesn't matter to me where he got the system from, since it seems to be properly licensed.
He can buy a support key.
Regarding your questions:
Yes, the adjusted injection timing is almost certainly related to the timing belt replacement.
Regarding the intake air temperature: I consider a difference of 1-2°C above the outside temperature to be unrealistic. A good intercooler cools the intake air by approximately 20K above the outside temperature when operating at full boost pressure. Be aware that the temperature increase is gradual, so the full boost pressure needs to be applied for several seconds before you'll see any change.
I can't really say anything about the CAN gateway off the top of my head.
Translated on 08-10-2026, 19:16.
mullemaus
Post23-08-2006, 20:06    Subject: VAG-COM Data: Interpretation and Analysis Quote
Actually, there's nothing really against it. For now, it doesn't matter to me where he got the system from, since it apparently has a proper license.
It's okay icon_wink.gif.
Regarding the CAN gateway, I can't say anything off the top of my head.
Re-encode the CAN gateway using the same encoding (00005) again. It will then automatically search for all 'participants.' If that doesn't improve the situation, try using the 'neutral' encoding of 00000. However, more information would also be helpful, such as the year of manufacture, the part number of the instrument cluster, etc. icon_wink.gif
Translated on 08-10-2026, 19:18.
Ross-Tech-Support
Post23-08-2006, 20:36    Subject: VAG-COM Data: Interpretation and Analysis Quote
Dauerschrauber wrote:
...when I use the TDI-Graph module, it tells me that my ignition timing is significantly retarded (well outside the tolerance range). Could this be related to the timing belt replacement a few thousand kilometers ago? Is that why it's no longer reaching its top speed? Immediately after the replacement, the engine was definitely properly adjusted at the VW dealership, but could it have readjusted itself?
Did you also choose the right motor?
while monitoring the "Air intake temp." (yes, I have installed the US version 6.07), it shows
Sensor broken, or what?
Which measurement block (MB) and which field are you specifically looking at?
In the error memory, there is always an error "CAN gateway: incorrect encoding" (which is displayed as 00005).
Basically, check the coding and, if necessary, change it. Even if the coding is correct, try recoding it as described before, as in your case, it's most likely a software error in the instrument cluster.
Translated on 08-10-2026, 19:20.
Dauerschrauber
Post23-08-2006, 20:58    Subject: VAG-COM Data: Interpretation and Analysis Quote
Hello everyone,
Thank you very much for your help! Just to reassure you about licenses: that is...
a completely legally purchased professional version, because my acquaintance is on vacation and therefore doesn't have time.
He even lent me his equipment so I could take my own measurements. Here are the exact data related to the measurements.
I'll send you the block information later. I'm also planning to take a longer highway trip tomorrow.
to really put the whole system to the test.
Regarding model selection in TDI-Graph: where can I adjust this setting? The only menu I can find is...
gefunden hatte, bei dem man ein best. Modell auswählen kann, war der Autoscan. At TDI-Graph.
According to the manual, only the fuel temperature and injection timing (data points 2 and 9 from the measurement values) are displayed.
block 000) are plotted against each other. I can gladly log the data and provide it with attachments if you like.
Matthias.
Translated on 08-10-2026, 19:23.
Ross-Tech-Support
Post23-08-2006, 21:08    Subject: VAG-COM Data: Interpretation and Analysis Quote
Regarding model selection in TDI-Graph: where can I adjust that? The only menu I found where you can select a specific model was the Autoscan function.
When starting TDI-Graph, select the engine variant in the bottom right corner.
Translated on 08-10-2026, 19:25.
Herr Antje
Post24-08-2006, 6:15    Subject: VAG-COM Data: Interpretation and Analysis Quote
Sorry guys, but where exactly is the V6 listed in the TDI graph? icon_razz.gif
Allow Group 4 to switch the "start time" from early to late (I believe this is in the basic settings, and requires the full version). The "early" setting should be between 4 and 0 (2 plus or minus 2).
I can't explain the temperature either; it's significantly higher. The sensor would be located in the lower left corner (from the driver's perspective).
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 08-10-2026, 19:26.
Ross-Tech-Support
Post24-08-2006, 10:31    Subject: VAG-COM Data: Interpretation and Analysis Quote
It's included in the current software version, but not yet in the older versions.
Translated on 08-10-2026, 19:27.
Dauerschrauber
Post24-08-2006, 10:54    Subject: VAG-COM Data: Interpretation and Analysis Quote
Hi!
I just checked, and my version is 1.4.1.0, which is the same as the one you mentioned.
The most up-to-date information is available at Ross-Tech. Unfortunately, I don't have a way to input the engine type.
Matthias.
Translated on 08-10-2026, 19:28.
Ross-Tech-Support
Post24-08-2006, 11:03    Subject: VAG-COM Data: Interpretation and Analysis Quote
http://vag-com.openobd.org/tour/tdigraph.png
Translated on 18-10-2026, 23:32.
Dauerschrauber
Post25-08-2006, 10:43    Subject: VAG-COM Data: Interpretation and Analysis Quote
Hi!
Shame on me! Now I've found it too, and I'm starting a new one this morning.
Test drive completed. However, the results were disappointing: the graphics look bad on the AKN.
While it looks quite different, the result remains the same: very little scattering within the cloud.
aber alle Punkte oberhalb der grünen Linie im Graph (=Einspritzung zu früh). Da will.
We probably have to take it to the workshop again to have it straightened out (or is it possible to...?
Can this also be done using VAG-COM yourself?
The temperature sensor in the low-level cooling system (or air duct) seems to be malfunctioning: it's reading 15 degrees.
After running for a while in idle, the outside temperature reading shows values around 40 degrees. Then, when...
When driving on the highway and constantly exceeding 2500 (up to 4000) RPM, does the temperature decrease?
slowly back up to around 20 degrees. Within this RPM range, the full boost pressure should be achieved.
"I'm concerned that the temperature is increasing instead of decreasing, or am I mistaken?"
The turbocharger is working, otherwise I wouldn't be able to accelerate to 180 km/h.
could (but no more was possible due to traffic).
At least there's some positive news: I've finished the coding for the CAN gateway.
changed from 00005 to 00007 (=automatic transmission + ABS brakes + airbags), and that's it.
Error codes in the memory have disappeared.
Matthias.
Translated on 18-10-2026, 23:34.
Herr Antje
Post25-08-2006, 12:19    Subject: VAG-COM Data: Interpretation and Analysis Quote
Hi!
I will.
You can also do it yourself with VAG-COM
Besides Vag-Com, you also need some other tools icon_cool.gif.
Remove the timing belt cover on the left (driver's side). Loosen the pump belt. Use a 10mm wrench to loosen the screws on the water pump wheel and turn it slightly counterclockwise. Tighten the screws. Adjust the tensioner pulley to the mark and tighten it. Reinstall the cover and warm up the engine. Then, check again with VAG-COM. Repeat the process until the tension is within the tolerance range.
Aktuell:
Translated on 18-10-2026, 23:37.
Dauerschrauber
Post26-08-2006, 19:57    Subject: VAG-COM Data: Interpretation and Analysis Quote
Okay,
I collected some more data today and compared it to the target values in the technical article.
"When comparing them, I noticed some significant differences, and I hope someone can help."
"to explain it to me. Initially, the measurements were taken while the engine was idling at its operating temperature of approximately 80 degrees."
danach Vollgas auf ebener Strecke mit Tiptronic im 4. Gang:
Measurements at idle (average):
Measurement block 3: 742/min, Air mass target: 279 mg, Actual: 282 mg, EGR pulse rate: 35%.
Meßwertblock 4: 742/min, ES-Beginn Soll -0,6, Ist +0,2, Taktverh. ES valve, 100.2%.
Meßwertblock 11: 742/min, Ladedruck Soll 1050mbar, Ist 1010mbar, Taktverh. LD-Valve 85%
Measurements taken at full throttle (average):
Measurement block 3: 3300/min, target air mass 860 mg, actual 830 mg, EGR pulse rate 95.5%.
Meßwertblock 4: 3300/min, ES-Beginn Soll +7,5, Ist +7,6, Taktverh. ES valve, 44%.
Meßwertblock 11: 3300/min, Ladedruck Soll 2100mbar, Ist 2100mbar, Taktverh. LD-Valve 54%
The MWB 11 looks relatively normal, but the values for MWB 3 are what make me suspicious.
and especially MWB 4, which deviates significantly from the values presented in the technical article.
What's wrong with this stupid car? (Besides the worn-out tires, which are my own fault.)
of course, also affected icon_sad.gif .... )
Translated on 18-10-2026, 23:41.
No new posts Diesel DPF Values: Interpretation & Meaning Diesel Engine Technology
No new posts VAG-COM: Interpreting LMM Values - A Guide Diesel Engine Technology
No new posts VW 1.6 TDI CR Specs: New Model Technical Data Diesel Engine Technology
No new posts Data for the 2.0 16V engine with filter Diesel Engine Technology
