Golf V TDI 8V/16V: No DPF - Which Engine?
RaZoR
Post29-08-2006, 23:12    Subject: Golf V TDI 8V/16V: No DPF - Which Engine? Quote
Hello!
There are many different opinions about it, and even the 'helpful' ones couldn't assist me.
It is said that two different engines are used in the Golf V 2.0 TDI (103 kW), supposedly since the 2007 model year.
It features two engine types: a two-valve engine (in conjunction with a DPF), and a four-valve engine with a balance shaft and modified injection (possibly piezo-electric) - without a DPF.
What is correct in this situation? What are the advantages and disadvantages of the 'newer' engine (if it is installed)?
Thank you.
Razor.
Translated on 24-09-2026, 10:37.
Post30-08-2006, 7:11    Subject: Golf V TDI 8V/16V: No DPF - Which Engine? Quote
Here too, searching can be your friend and might be helpful.
/viewtopic.php?t=12361&highlight=touran
Translated on 24-09-2026, 10:38.
No new posts Golf 1J Wiper System Not Working? Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 PD Engine (ATD) - No KI, 2000 On-Board Diagnostics (OBD)
No new posts Golf 6 front windshield wipers not working, motor OK Electrical Systems, Vehicle Electronics, Multimedia
No new posts Starter Motor: RPM to Start Engine On-Board Diagnostics (OBD)
No new posts Engine Longitudinal, Rear Transaxle: Which Brand? Diesel Engine Technology
