Can you read the oil pressure?
derkater
Post28-09-2008, 11:13    Subject: Can you read the oil pressure? Quote
My previous search in the repair manual was unsuccessful. Therefore, my question is whether it is possible to read the oil pressure (via the measurement block).
Thank you and greetings.
Stephan.
Post28-09-2008, 11:22    Subject: Can you read the oil pressure? Quote
Depending on the vehicle and the installed control unit, this can be done through the instrument cluster.
Unfortunately, it doesn't display the oil pressure as an 'x bar' value, but only indicates whether it's 'sufficient' or not. Take a look at what type of oil pressure switch is installed and at what pressures it switches.
derkater
Post28-09-2008, 11:49    Subject: Can you read the oil pressure? Quote
Okay, then I guess I should take a look at the accessories. It's strange that there are no specific values available for the gasoline version.
Best regards, Stephan.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Engine shuts down unexpectedly, oil pressure warning ligh... Diesel Engine Technology
No new posts "Low oil pressure warning briefly appears in the driver i... Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts Oil pressure BSS Diesel Engine Technology
