VW OBD Access: Car Not Accessible?
dreamingof8a
Post29-08-2026, 15:30    Subject: VW OBD Access: Car Not Accessible? Quote
"Does anyone else experience the problem where I can easily read error codes and scan control units, but apparently, VW's diagnostic tool can't even read the VIN? Three weeks ago, it worked fine at the same VW dealership. The only thing that happened in between was that a tuning shop made a backup of the engine control unit's settings, but they claim they didn't write anything new."
At the same time, I can access the system without any problems, and no errors are displayed. Also, a local repair shop was able to access the OBD interface using Bosch software on the same day.
According to a technician at VW, it could be due to a fault in a cable that is only used by the VW system for diagnostics.
Maybe someone has an idea what this could be?!
Thank you!
Translated on 29-08-2026, 16:04.
Karma: +807 / -0   Thank you, like it!
Post31-08-2026, 9:51    Subject: VW OBD Access: Car Not Accessible? Quote
Usually a cable or connector problem, loose pins in the diagnostic socket, or dirt.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Translated on 31-08-2026, 9:52.
No new posts Car Vacation Checklist: Essential Vehicle Prep General Tips
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vehicle/model not supported On-Board Diagnostics (OBD)
No new posts VCDS AutoScan - Vehicle selection no longer working On-Board Diagnostics (OBD)
No new posts I can't find it... Diesel Engine Technology
No new posts Intake Air Temperature Sensor for Audi ARL Engine Diesel Engine Technology
