MFD2 in Golf 4
Bolzer
Karma: +14 / -0   Thank you, like it!
Post10-09-2006, 7:10    Subject: MFD2 in Golf 4 Quote
Hi.
Ich habe einen G4 BJ 03.2001 ASV. Hab zur Zeit das MFD vers.D drin mit FIS. Möchte aber das MFD2 nachrüsten. Zum Anschliessen mit CAN-Adapter usw, müsste ich zurecht kommen. Weiterhin möchte ich mein Display im Tacho nutzen(Senderanzeige, Pfeildarstellungen,usw). Ist Is that possible?
Best regards, Bolzer.
Translated on 18-07-2026, 0:51.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post10-09-2006, 12:31    Subject: MFD2 in Golf 4 Quote
Hello.
How are you going to do that? Are you going to saw through the dashboard with a flexible shaft tool?
The MFD 2 uses CAN bus, which you might encounter problems with. Also, it will likely never fit perfectly in a Golf 4.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi SQ5 8R Cvub
Back to top Profile PM Email
vagtuning
Post10-09-2006, 13:20    Subject: MFD2 in Golf 4 Quote
Well, I just think it's quite nice.
http://img90.
/img90/2789/kalini1101898167mfd2mk4no0.jpg
Anyone who wants to use this with a Passat should evaluate it carefully.
http://www.vwnavi.com/vwnavi/forums/showthread.php?t=1832
as well as
http://www.passat3b.de/phpBB2/viewtopic.php?t=42910
And the Audi RNS-E system in the 3B generation is also compatible.
http://www.passat3b.de/phpBB2/viewtopic.php?t=47104&postdays=0&postorder=asc&start=0
Translated on 18-07-2026, 0:52.
pa-mm6
Post10-09-2006, 13:28    Subject: MFD2 in Golf 4 Quote
Hello.
Well, it's a matter of taste, but you can certainly do it with a hammer and chisel icon_cool.gif.
Audi SQ5 8R Cvub
Translated on 18-07-2026, 0:53.
Bolzer
Post10-09-2006, 20:50    Subject: MFD2 in Golf 4 Quote
@vagtuning
Excellent installation! Did you have to remove anything from the dashboard, or what modifications did you have to make? How about the MFA (Multi-Function Display)? If you have one, did you connect it? I'd like to learn more about the installation process.
Translated on 18-07-2026, 0:54.
vagtuning
Post10-09-2006, 21:00    Subject: MFD2 in Golf 4 Quote
This is not my installation, but it should merely serve as proof that it works icon_wink.gif.
I haven't done it myself yet.
Bolzer
Post11-09-2006, 5:25    Subject: MFD2 in Golf 4 Quote
Hi.
Do you happen to know whose car that is?
Translated on 18-07-2026, 0:55.
vagtuning
Post11-09-2006, 6:17    Subject: MFD2 in Golf 4 Quote
Check out the forum at www.golfiv.de and then search for 'mfd2'.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
