LWR Sensor Check: How to Test & Diagnose
bindpe
Karma: +5 / -2   Thank you, like it!
Post10-09-2006, 21:35    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Hello.
I had previously reported on the xenon problems my friend was experiencing with his Passat 3BG.
Nach neuerlchen Auslesen des FSP kommt jetzt die Meldung das der Geben links Vorne einen schluss gegen Masse hat. Now, my question is:
Where exactly is the sensor located?
Can I test it, for example, with a multimeter?
Nach welchen prinzip areitet dieser Sonsor? Resistive?
How can I be sure that the sensor is actually defective and not due to a broken cable or something similar?
In the workshop, they also mentioned that it's possible the control unit might be faulty; is that a possibility?
Thank you for your responses.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 01-08-2026, 15:28.
pax
Avatar-pax
2000 Volkswagen Passat
Post11-09-2006, 5:36    Subject: LWR Sensor Check: How to Test & Diagnose Quote
A lever is mounted on the left lower control arm (the lower front steering arm) and this lever activates the sensor. You can see this if you are standing underneath the car.
If a sports suspension is installed, the sensor may be outside of its operating range, which can cause an error message to be generated.
As far as I remember, there are three pins on the sensor.
[ASSUMPTION] It should be possible to measure variable resistance values between the two, depending on the sensor position. [/ASSUMPTION] The sensor at the rear axle would serve as a reference object.
Bye.
peace
Translated on 01-08-2026, 15:30.
bindpe
Post11-09-2006, 5:47    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Thank you for the quick response.
No, it doesn't have a sports suspension installed. The xenon headlights are no longer functioning properly, which is why we read the fault code: the entry indicated "short circuit."
In the measurement group of VAG-COM, a value of 0V is also displayed. The rear sensor is providing approximately 1.8V.
I just want to make sure that the sensor is actually defective and not something with the control unit. That's why I wanted to know if it can be checked with a multimeter.
Spritmonitor.de
Translated on 01-08-2026, 15:32.
Ross-Tech-Support
Post11-09-2006, 6:50    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Do you have the ECU part number and also the current sensor values ready?
The sensors are always displaying voltage values, but with a reasonably up-to-date version of VAG-COM, you should also see target values and hints/information.
Translated on 01-08-2026, 15:33.
bindpe
Post11-09-2006, 16:42    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Hello Sebastian,
Unfortunately, I don't have the Sg number readily available. The sensor reading remains at 0.02V regardless of how much weight is in the car.
The sensor on the rear axle was reading approximately 1.8V and its value also changed depending on the load.
I would like to understand the sensor better before buying a new one based on suspicion.
Spritmonitor.de
Translated on 01-08-2026, 15:34.
Post11-09-2006, 17:46    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Then, as mentioned above by PAX, take a look under the car and check if the sensor still has a mechanical connection to the axle. If something has come loose, you might be experiencing exactly the problem you described.
There's not much more that can be done regarding the diagnosis unless you've already checked for any mechanical issues. The next step would then be to check the connectors.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 01-08-2026, 15:35.
bindpe
Post11-09-2006, 18:22    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Okay, I'll take a look at the car and possibly remove the wheel. I found a picture online, but it's from an A4, so it might look similar on my Passat.
Does anyone have a schematic? The sensor is just a resistor that changes value. I'm interested in knowing which pins I need to measure between.
Spritmonitor.de
Translated on 01-08-2026, 15:36.
bindpe
Post11-09-2006, 18:27    Subject: LWR Sensor Check: How to Test & Diagnose Quote
Here's the picture.
 File size:  119.02 KB
 Viewed:  24604 times
Spritmonitor.de
Translated on 01-08-2026, 15:37.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Inspect AHU Diesel Engine Technology
No new posts ZMSwing Check: Improve Your Golf Swing Diesel Engine Technology
No new posts Check Catalytic Converter: Symptoms & How To Diesel Engine Technology
No new posts VCDS: Check Turbocharger Boost Pressure On-Board Diagnostics (OBD)
