Webasto Thermo Top Disassembly: How To?
Nebelwerfer_TDI
Post24-09-2006, 18:09    Subject: Webasto Thermo Top Disassembly: How To? Quote
Hello!
Since I unknowingly put my Thermo Top into a state of disrepair about 3 years ago by adding the wrong type of fuel, and now the 35i is being 'completely overhauled,' I removed the auxiliary heater and tried to disassemble it.
The part with the blower and pump was easy to detach (only 2 screws), but it's attached to an aluminum part that is about 15-18mm thick and round. This part can be pulled out about 1.5-2cm, but then it gets stuck. Now I'm not sure whether I should risk prying it apart with a screwdriver and a chisel, or if there's a less forceful way to do it.
I would be grateful for any information (including speculations) and possibly blueprints, etc.!
Best regards, Nebelwerfer.
Translated on 06-10-2026, 16:38.
wolfi_b
Post25-09-2006, 8:08    Subject: Webasto Thermo Top Disassembly: How To? Quote
There is a workshop manual, which might help you.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 06-10-2026, 16:39.
Nebelwerfer_TDI
Post25-09-2006, 10:01    Subject: Webasto Thermo Top Disassembly: How To? Quote
Thank you, I'll read it through icon_smile.gif.
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Webasto Thermo Top C On-Board Diagnostics (OBD)
No new posts Webasto Thermo Top with CAN Bus: Installation & Guide Transmission, Chassis, Body & Interior
No new posts Standheizung Webasto Thermo Top Diesel Engine Technology
No new posts Webasto Thermo Top: Outside temperature sensor Transmission, Chassis, Body & Interior
