Golf 3 Corrosion: Fuel Filler Neck Repair Guide (Solution)
Michael II
Post04-12-2002, 11:34    Subject: Golf 3 Corrosion: Fuel Filler Neck Repair Guide Quote
Golf III, manufactured up to 02.94, corrosion at the fuel filler neck.
Affected vehicle identification numbers:
Up to 1 hour, 480,000.
Up to HR B 092 000.
Until 1 HR, P 420,000.
Cause:
Contact corrosion between the connector pin and the threaded insert due to an unfavorable material combination.
Solution:
For minor corrosion, preserve the connector with protective wax.
Otherwise, replace the fuel tank and install a new grounding strap, part number 1H9 201 142 A.
Tschüss
Michael II
Translated on 11-10-2026, 19:41.
Ratings - Golf 3 Corrosion: Fuel Filler Neck Repair Guide
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust Corrosion Protection: Tips & Solutions Transmission, Chassis, Body & Interior
No new posts Rust on Audi 80 Avant trunk lid - rear wiper leaking Transmission, Chassis, Body & Interior
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
