VAG-COM using a USB-RS232 adapter?
Go to page: 1, 2  Next
kalle
Post31-10-2002, 9:04    Subject: VAG-COM using a USB-RS232 adapter? Quote
Has anyone already managed to get Ulf's adapter working with a USB-to-RS232 adapter?
I have this adapter and I just can't get it to work.
Neither with the simple version nor with version 2.2!
If I go to 'Options' and then to 'Test' in VAG-COM, I always get the following message: COM Port Status OK; Adapter Status 0 – Found, Ready; Fast-Synch Compatible: NO.
What should actually be here???
The entire circuit seems to be working, but I apparently can't receive any data.
Anyway, you can faintly hear a 'ticking' sound coming from the dashboard. The control units are also not responding. I have also tried various baud rates, unfortunately without success.
The USB-RS232 adapter has been working with all devices (mouse, modem) and even with an optical adapter for a digital multimeter.
Does anyone have a solution for my problem? Unfortunately, I don't have a way to test it on another computer with a 'real' COM port.
Best regards, Kalle
Vento TDI EZ 3/95 1Z 66kw
Post31-10-2002, 11:15    Subject: Re: Another adapter in the game :-( Quote
kalle wrote:
If I go to "Options" and then to "Test" in VAG-COM, I always get the following message: COM Port Status OK; Adapter Status 0 - Found, Ready; Fast-Synch Compatible: NO.
In any case, you can faintly hear a "clicking" sound coming from the dashboard. The control units are also not responding. I have also tried various baud rates, unfortunately without success.
Hi Kalle
Found, Ready "No" is not critical.
The positive adapter message is, however, not a guarantee of a actually functioning communication with the vehicle. . .
I also constantly see updates from the dashboard, regardless of whether communication is successful or not (e.g., when the adapter is incorrectly configured).
As a possible explanation for failure on the USB port (if it's operating as a normal COM port), the only thing that immediately comes to mind is that the USB/COM adapter is likely introducing some timing issues = signal delays that are not tolerated by VAGCOM or the vehicle's onboard electronics.
Post31-10-2002, 11:42    Subject: Re: VAG-COM über USB-RS232 Adapter? Quote
The ticking in the dashboard is normal during data transfer...
When it comes to USB to Serial adapters, there are different systems. Some systems only function at the software level within the Windows environment, while others are recognized as "real" hardware within the computer. Those who only communicate via Windows are the cheapest and unfortunately also the worst - they definitely won't work with VAG-COM!
Unfortunately, there is no general statement about which adapter does what and how to distinguish them - practice is better than theory...
kalle
Post31-10-2002, 18:05    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]Hallo
erstmal danke für eure Mühe. Was mich nur wundert, muss nun eigentlich bei „Adapter Status“ eine 0 oder eine 1 stehen?
Kalle
kalle
Post24-12-2002, 20:54    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]Hi,
wollte nur mitteilen das ich mein Problem gelöst habe!
Mit einem USB Adapter mit FTDI Chipsatz.
Läuft tadellos an Ulf seinen Adapter! (Version 2.2)
Sieht ein bisschen anders aus als auf den Bild und Treiber für Windows XP sind auch bei!
Habe es aber nur unter Windows 98 und 2000 probiert! Und kostet nur 23.85€.
Frohe Weihnachten Kalle
Post25-12-2002, 12:09    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]
Hi Kalle
Dir und allen anderen hier auch frohe Weihnachten!
@Rainer:
Das Problem fehlender RS 232 Schnittstellen werden wohl künftig noch mehrere Leute haben, da der Anschluß wohl aussterben wird . . . ??
Was hältst Du davon, einen Hinweis auf den FTDI-Adapter als "eventuelle Ohne-Gewähr-Möglichkeit" in den Diagnose-Fachartikel mit aufzunehmen?
Post25-12-2002, 21:42    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]
Hallo Ulf,
klar, besser man nimmt einen wo man weiß daß es damit überhaupt schonmal geklappt hat.
Dazu bräuchte ich aber den genauen Typ des Teils...
kalle
Post25-12-2002, 23:31    Subject: VAG-COM using a USB-RS232 adapter? Translating...
Wie gesagt hat keine Ähnlichkeit mit dem Bild bei Reichelt!
mfG Kalle
Post10-02-2004, 12:43    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]
Hi Brösel,
Ulfs Adapter 2.2 (Versionsnummer, weiß die aktuelle nicht) arbeitet mit Optokopplern.
Zu finden im Diagnose Fachartikel.
/viewtopic.php?t=3089
Der Adapter/Bausatz im Onlineshop basiert auf dem MAX232 und hat noch eine Reihe weiterer Vorteile, diese sind aus der Produktbeschreibung ersichtlich.
Verwendet man einen USB-RS232 Adapter vor dem eigentlichen Diagnoseadapter, kann es funktionieren, es muß aber nicht.
Natürlich bedeutet die nochmalige Umsetzung weitere Verzögerungen in den entsprechenden Signalen/Protokollen, es kommt dann auf die Hardware des Umsetzers an, was für einen USB-Treiber das Teil verwendet, welche USB-Transfermodi etc...
Weil neuere PCs fast nur noch mit USB Schnittstellen ausgerüstet sind, bastele ich gerade an einem Diagnoseadapter für USB.
Wegen Wohnung fliesen/streichen/verputzen bin ich leider noch nicht so doll damit weitergekommen, wird noch mindestens 2-3 Wochen dauern. icon_rolleyes.gif
http://shop.dieselschrauber.de/product_info.php/products_id/46
http://shop.dieselschrauber.de/product_info.php/products_id/329
joergs
Post10-02-2004, 13:53    Subject: VAG-COM using a USB-RS232 adapter? Translating...
Post10-02-2004, 14:09    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]
joergs
Post10-02-2004, 14:26    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]super !!! meldest dich, wenn du soweit bist !?
Post10-02-2004, 14:31    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]
harix84
Post10-02-2004, 17:47    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]
Ich habe mir einen USB-Seriell Adapter, für 10EUR bei e*** gekauft.
Der Adapter funktioniert mit VAG-COM auf WinXP bei meinem Auto, beim Kumpel nicht.
Bei e*** läuft der Adapter unter der Bezeichnung "USB Seriell Converter Adapterkabel 9pol" und wird von dem Verkäufer "play_it"angeboten. Der Hersteller des Adapters ist INLINE.
Gruß harix84
joergs
Post10-02-2004, 18:15    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]schön für dich ! aber wie schon mehrfach angesprochen, ist es keine garantie, daß es wirklich bei jedem funktioniert ! da spielen so viele faktoren um notebookhardware, adapterhardware etc eine rolle !
Dan.jel
Post14-02-2004, 7:36    Subject: VAG-COM using a USB-RS232 adapter? Translating...
[Translating...]Hmm...
Letztens hab ich doch im Shop noch das Diagnosegerät mit USB gesehen?
Wurde der wieder rausgenommen?
Wollte nämlich gerne einen haben, würde mich sonst auch gerne als Tester zur Verfügung stellen! icon_wink.gif
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts USB to RS232 Adapter On-Board Diagnostics (OBD)
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts VAGCOM Adapter: Change/Info on Optocouplers Diesel Engine Technology
No new posts KKL+CAN Diagnostics: Troubleshooting & Solutions On-Board Diagnostics (OBD)
