Zak1976
Joined: 03/09/2005 Posts: 225 Karma: +0 / -1 Location: Barendorf
18-03-2006, 19:39 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
I might be able to get a relatively inexpensive set of PDE injectors from a Golf GT with the 170PS TDI engine. Visually, they look the same as the ones from the ARL engine. Would it be possible to swap them? The PDE injectors from the 170PS TDI use piezo technology and operate at a maximum pressure of 2200 bar (compared to 2050 bar for the ARL), which should provide a good performance boost (after adjusting the engine control unit).
Do you mean that this is possible, or would the entire fuel injection unit need to be replaced?
When combined with a hybrid charger, this setup should produce a power output of around 190 horsepower (possibly even more) without overloading the high-pressure fuel pump (PDE) or turbocharger. With an additional oil cooler, it should be quite reliable. What are your thoughts on this?
Fährt mit Golf 3 TDI Umbau (von AFN auf ARL)
Translated on 11-09-2026, 4:45.
Profile PM Email |
mullemaus Guest
18-03-2006, 22:19 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
What license plate code is that supposed to be? Or, do you have the part numbers for these PDE's handy?
Translated on 11-09-2026, 4:46.
Zak1976
18-03-2006, 22:26 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Unfortunately, I don't have either of those. The engine is also brand new and is currently only offered in the Seat Altea, but it's now also available in the Audi A3 and VW Golf GT. It's a 2.0L 140hp TDI engine that, at least in some versions with PDE (Piezo PDE, 2nd generation) injectors, has a flow-optimized intake to the turbo and runs with 50 or 100 bar more boost pressure. The engine control unit is also different. As far as I know, the engine block is based on the 1.9L design, but with larger pistons and optimized channels. The cylinder head for the 140hp models has been upgraded to 16v technology.
Okay, here's the translation:
"So, another question: Are there any head gasket options available for a 1.9 engine that reduce compression? If so, where can I find them and what are the costs? If not, where can I get one custom-made, and what material would it be made of?"
Translated on 11-09-2026, 4:47.
Profile PM Email |
mullemaus Guest
18-03-2006, 22:49 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Unfortunately, no, I'm missing both of those. The engine is also brand new and is currently only offered in the Seat Altea, but it is now also available in the Audi A3 and the VW Golf GT. It's a 2.0L 140hp TDI engine, which, at least for some versions with PDE (Piezzo PDE 2nd generation), has a flow-optimized intake to the turbo and runs with 50 or 100 bar more boost pressure, and the engine control unit is also different. As far as I know, the engine block is from the 1.9L with larger pistons and optimized channels. The cylinder head for the 140hp models has been converted to 16v technology.
I'm not familiar with that, at least not currently or until now.
Then, another question right away: Are there any decompression cylinder head gaskets for the 1.9 engine? If so, where can I find them and what are the costs? If not, where can I have them made, and what material are they made of?
Pistons, with increased displacement of 2.0 or 2.1 liters, are available.  These also reduce the compression ratio.
Translated on 11-09-2026, 4:49.
Steffarn Profi-Schrauber
19-03-2006, 1:27 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
To be honest, you can't even attach those to the cylinder head.
In the 1.9 TDI engine, the injectors are held in place with a wedge, while in the 2.0 TDI engine...
They will all be fastened with 2 screws.
Unfortunately, I don't know anything about the brand new 1.9 Pd.
B.Eng (FH) u. KFZ Meister
Translated on 11-09-2026, 4:51.
Profile PM Email Garage |
Zak1976
19-03-2006, 22:54 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
"Yes, are you sure? Visually, they look like the ones from the 1.9 PD TDI."
Translated on 11-09-2026, 4:52.
Profile PM Email |
mullemaus Guest
19-03-2006, 23:02 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
I also mean that the 'new' ones are threaded on both sides. The older ones are threaded on only one side (we know the result  ), and the new ones are like this.
Rudi Guest
20-03-2006, 7:39 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
If it's using piezoelectric injectors, you'll also need a Siemens control unit, because the power stages within the control unit are completely different.
Rudi
Translated on 11-09-2026, 4:53.
Zak1976
20-03-2006, 18:01 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Thank you for your replies; I guess I'll have to abandon the idea.
Profile PM Email |
Zak1976
31-03-2006, 16:46 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Hello everyone,
...forget about it, but could the PDE (pressure differential sensor) from a V10 TDI fit?
Part numbers are PDE-P1.4/80/560 S 220 = 07Z 130 073 H and PDE P1.1/80/560 S 228 = 070 130 073 N. Could someone explain the nomenclature to me? What does, for example, PDE-P1.4/80/560 S 220 mean? Do these fit in the ARL (in terms of form factor/size/mounting/electrical control)?
Translated on 11-09-2026, 4:54.
Profile PM Email |
31-03-2006, 16:59 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Zak1976 wrote: | Hello everyone,
Teilenummern wären PDE-P1.4/80/560 S 220 = 07Z 130 073 H und PDE P1.1/80/560 S 228 = 070 130 073 N. Könnte mir jemand die Nomenklatur erklären, was bedeutet z.b PDE-P1.4/80/560 S 220 ???. Passen die in den ARL (von der Bauform/Größe/Befestigung/elektr. Anstevelopment) |
Even if they would fit.
He draws his power from 10 PD elements.
I therefore doubt that they will be significantly larger than those of the 1.9 version. ASZ, etc.
Translated on 11-09-2026, 4:55.
mullemaus Guest
31-03-2006, 17:51 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
glaube also kaum damit die Größer sein werden als die von 1,9. ASZ, etc.
Sure, why not  ?
PDE-P1.4/80/560 S 220 I have highlighted the hole size in red.
and PDE-P1.4 are not compatible with PDE P1.1. I believe that 1.4 already refers to the piezo elements, while 1.1 refers to the 'older' ones.
Translated on 11-09-2026, 4:56.
Zak1976
31-03-2006, 20:19 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
"Slowly, some clarity is emerging. Would the part number PDE P1.1/80/560 S 228 = 070 130 073 N be a suitable replacement?"
Translated on 11-09-2026, 4:57.
Profile PM Email |
mullemaus Guest
01-04-2006, 15:15 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Theoretically, yes. It's just a little expensive to test. The mounting of these PDEs is identical to that of the AXD (96/130), so with M6*55 screws. I mean, these are also only attached on one side. If anyone has a set, I'd be happy to make myself available for testing.
Translated on 11-09-2026, 4:58.
mullemaus Guest
15-10-2006, 13:52 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
To supplement: a set of (i.e., 4) 560 series items costs approximately €1457 for exchange.  This is through a supplier network and includes tax.
Skoda Doc Blaumann
Joined: 01/18/2006 Posts: 47 Karma: +1 / -0 Location: Malsfeld
Registered VCDS User
22-10-2006, 16:37 Subject: TDI Engine Swap: PE Parts for ARL 170PS? |
Okay, since we're talking about piezo technology: Have you seen how quickly the idle speed control works on the piezo injectors? It's amazing, especially compared to the normal BKD engine (2.0L 4V 103kW).
97´Golf Variant Joker AFN
03´Bora ARL UK Import
93´Mitsubishi GTO UK Import
Translated on 11-09-2026, 4:59.
