Climate maintenance for the 1Z
edward
Post23-10-2002, 13:31    Subject: Climate maintenance for the 1Z Quote
Hello everyone.
'Can anyone provide me with a detailed description of an air conditioning system maintenance procedure? I haven't had it serviced in about 2 years, and I'd like to get it checked and refilled before it completely breaks down.' What kind of fluid do I need, and do I require any other special parts or tools?
Thank you!
Post23-10-2002, 13:42    Subject: Re: Climate control maintenance for the 1Z Quote
edward wrote:
Do I need any other special parts or tools?
Yes, an air conditioning refrigerant filling device!! (Cost > €4,000)
Post23-10-2002, 13:49    Subject: Re: Climate control maintenance for the 1Z Quote
edward wrote:
Can someone provide me with a detailed description of air conditioner maintenance?
Yes, just drive as long as the air conditioning is working (cooling).
If the refrigerant eventually leaks out due to a leak or normal diffusion, it is recommended to add a leak detection solution to the new refrigerant and to replace the dryer.
I haven't had anything done for about 2 years, and I wanted to have a maintenance check with a refill performed before the system completely breaks down.
Nothing can go wrong because a pressure switch will simply shut down the system if the filling is insufficient.
Which liquid do I need, and do I need any other special parts or tools?
As Bertil already mentioned, this kind of service isn't worth it for home use. -> Use a Bosch service or regular HVAC services (for buildings).
edward
Post23-10-2002, 14:03    Subject: Climate maintenance for the 1Z Quote
Thank you for the answers...
I suppose I can continue driving with a clear conscience.
Post23-10-2002, 14:21    Subject: Climate maintenance for the 1Z Quote
Hello Thomas,
Okay, I had forgotten about that point. Occasionally, replace the pollen filter, and for cleaning, use warm water, then spray with Febreeze – that's all.
At the very least, when it starts to smell like dead cats coming from the ventilation slots, you usually replace the pollen filter yourself icon_wink.gif.
My last but one cleaning was after approximately 2 years of operation, and it wasn't strictly necessary (there was hardly any leakage and no odor).
Where did the post go? Thomas had correctly pointed out the need for cleaning.
Thomas K
Post23-10-2002, 14:28    Subject: Climate maintenance for the 1Z Quote
The maintenance also includes cleaning the evaporator. The hot air from the engine condenses on the evaporator, forming condensation. Dirt and pollen stick to the moist surface, and the decomposition process can be clearly smelled. The lamellae are cleaned and disinfected during maintenance.
In addition, the refrigerant (often R314a) may need to be refilled. R314a is very volatile and diffuses through the hose material. The pressure is decreasing, which leads to a reduced cooling performance of the air conditioner.
I recently had both of these procedures done on my father's Astra. At first, I was skeptical about whether they would actually make a difference. Now I am convinced.
Thomas.
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Batterie (Akkumulator): Tipps zu Check und Wartung Technical Articles
No new posts Audi A3 TDI 8L Klima 1.Lüfterstufe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate leakage due to improper maintenance? Urgent!! Transmission, Chassis, Body & Interior
No new posts White smoke from AC when starting car Transmission, Chassis, Body & Interior
No new posts Golf 3 Drum Brakes: Maintenance or Replacement? Transmission, Chassis, Body & Interior
No new posts Wartung / Leistungserhaltung "alter" Motoren Diesel Engine Technology
