Cylinder Location: Front or Rear?
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
Post23-07-2016, 17:51    Subject: Cylinder Location: Front or Rear? Quote
Hello everyone,
Okay, I'm going to ask a really silly question now, although it seems quite stupid to me at the moment.
Passat V6 TDI, BDH, 132 kW.
Where is the first cylinder located in a V6 TDI engine?
On the front right side, which is the passenger side, either at the rear of the fender liner or at the front of the radiator.
According to the camshaft timing, the first cylinder should be at the injection wall when at top dead center.
Is there an exploded diagram available for that?
"Answers would be great, because I've already taken the old waves out, and the markings on the new ones don't seem right."
Michi.
Translated on 08-09-2026, 18:28.
Karma: +591 / -0   Thank you, like it!
Post23-07-2016, 22:39    Subject: Cylinder Location: Front or Rear? Quote
Hi!
According to DIN xxx, the first cylinder is located opposite the main power output side/clutch.
Okay, in the front.
Edit: I still had some uncertainty about something:
Now from Wikipedia:
However, which cylinder receives the number 1 is not uniformly defined. In the automotive sector, German manufacturers regularly refer to DIN 73021.[7] According to this standard, the cylinder that is located on the left from the viewer's perspective receives the number 1; this view must be from the end of the engine where the power output/flywheel is NOT (!). [7]
Translated on 08-09-2026, 18:29.
bloesch
Post24-07-2016, 6:45    Subject: Cylinder Location: Front or Rear? Translating...
[Translating...]
http://wiki.xedos-community.de/images/2/20/Zylinderanordnung-zzp.gif
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post24-07-2016, 18:46    Subject: Cylinder Location: Front or Rear? Quote
Unfortunately, the diagram in the link does not apply to Audi V6 engines.
In Audi's 6-cylinder engines, the first cylinder is located on the front, passenger side.
On the right side of the vehicle, the cylinders are arranged from front to back as follows: 1-2-3.
Then, on the left side, you'll find cylinders 4, 5, and 6.
It's quite easy to determine, for example, by checking the part number on the valve covers.
059103470Q Cylinder head cover, right side, cylinders 1-3.
059103469AA Cylinder head cover, left side, cylinders 4-6.
Regards, Mpire.
Translated on 08-09-2026, 18:31.
bloesch
Post25-07-2016, 5:35    Subject: Cylinder Location: Front or Rear? Quote
The schema in the link unfortunately does not apply to Audi V6 engines.
Oops... I hadn't noticed that... I was only concerned with cylinder 1.
You are absolutely right icon_redface.gif.
Translated on 08-09-2026, 18:32.
No new posts Golf 5 Pulls to One Side: Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, 8L, front seat lock damaged Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Noise: Gurgling Sounds (Up to 01/99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: Right Front Inner Fender Liner Transmission, Chassis, Body & Interior
No new posts Overhaul front brake caliper Transmission, Chassis, Body & Interior
No new posts Retrofitting front parking sensors Electrical Systems, Vehicle Electronics, Multimedia
No new posts T5 Front Wheel Bearing Replacement Transmission, Chassis, Body & Interior
